I installed a pre-owned SW chip--91 octane, pre-muffler, sport muffler. I've since swapped the catalytic converter for an M&K pre-muffler and am running a stock Dansk muffler (60mm tip, non-sport). I can get 93 octane in my local area and where I drive.
Is it worth returning the chip to Steve for a 93 octane version? Would it be worth installing a sport muffler? If so, which is best with minimal other mods and expense? Which is it better to do first? Should I do both? Thanks, Dave
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
If you did not purchase from him my understanding is that he will not update the chip unless you pay for a new one.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I would say no. I don't think the cost justifies the marginal return in performance.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
i think i'd probably throw on a sport muffler of some kind (i'm running M&K) and call it a day. i have to think the difference between 91 and 93 octane settings are somewhat minimal. i have the SW chip you're considering - 93/pre-muffler/sport muffler - with that config.
'04 GT3 '97 C4S '90 C2 '86 951 |
a.k.a. G-man
I was wondering the same .
I bought the chip for a stock motor. Since then I have 964 cams, SSi's, m&k dual out muffler, and a cup airfilter cover. I think I want to upgrade the chip ( that i bought directly from him)
Сидеть, ложь, Переворачиваться |
slightly tangential, but if thinking of upgrading, wouldn't the best "bang" be achieved by having a chip configured from a dyno run's results -- this would best capture the specific engine's characteristics
d |
Yes, but that's rather pointless if you just have a stock engine with a muffler.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Member 911 Anonymous
Have you asked Steve?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I asked Steve this very question via email. He replied in detail that he will not reprogram for chip owners that did not originally buy the chip from him.
That said-I have a sw chip that I would like to trade for a milder version. My chip is a 24 pin version, for headers, sport exhaust, and 93 octane. I would like a stock/stock version for 91 octane. Anyone? |
The best thing about a SW chip is that he customizes it based on Air/Fuel ratio and then insures that there is no lean areas and you get the best results. If you are going to get a new chip you should get the best for the money and SW uses your dyno results to improve your performance.
I got a custom chip and it works great and I get good advice on performance improvements. I just added the custom chip for 93 oct gas and the bypass pipe and the car (86 Carrera) produces 210 wheel HP (I also replaced all tune-up items and the O2 sensor, spark plugs and wires and had the injectors cleaned by Marren). |
I recall a thread about a SW chip with multiple maps contained on it and switchable via a toggle switch. Is that available from anyone?
Sherwood |
