Exhaust sounds like machine gun when I accelerate
Porsche 911SC, 1981
All, Next drama. when I accelerate and apply a large amount of accelerator (like passing a car), I get a tatatatatatatatatat. Sounds like an M60A1. Anyway, when I take my foot off the accelerator or slow acceleration the noise goes away. It is easy to control - just don't gun it! Any opinions? Thank you. MikeW P.S. love the spell check feature! Last edited by mweist; 08-05-2014 at 10:47 AM.. Reason: spelling in the title was incorrect |
Member 911 Anonymous
Chain Tensioner?
Have a friend video tape it and post here
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Head slap, due to broken head studs?
This would be my guess as well.
Pull lower valve covers and see if anything falls out.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Might be an exhaust leak, but the symptom is classic for escaping exhaust gasses from a cylinder head/cylinder that has become loose as the result of broken head studs.
FYI; At this point, if the cause is failed head studs (highly likely) every time that the car is driven more damage will result.
Keep the Shiny Side UP! Pete Z. |
Thank you all!
That's not ok. It is supposed to sound like a MG 42.
http://www.carrera-32.com |
RETIRED
If it sounds like playing cards in the bicycle spokes, it's head studs.
Pull the lower valve covers and look for bolts with snapped head studs.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Brew Master
My brother had his distributor go bad and I think it caused all kinds of popping.
The best suggestion I saw here was to take the valve covers off and look for broken studs. |
tell me the truth, do I have to remove the engine to ultimately fix this?
ROW '78 911 Targa
If the head studs are the problem, yes pull engine and tear it down.
Brew Master
Does it only do this under load are will it pop setting still in neutral? |
My first thought is
Well actually second thought after reading the other responses and that first thought actually would be no comment!
![]() I would think it is severely leaning out and the problem is how the timing is firing off a bad mixture at the higher rpms! The head studs would be a different sound than you described and you would probably pick that up in the lower rpms also! Last edited by TCracingCA; 08-05-2014 at 01:37 PM.. |
grateful user
![]() sound like head to jug seal has expired..this is the end result if you keep driving it. Lots of expensive machine work,,
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Maybe you got: https://www.youtube.com/watch?v=0TIZb8d87AI
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
The engine noise only appears in gear and in acceleration. At idle, it will not pop, though it almost sounds like it could if under stress.
It's definitely not Phil Avlin and his 'One bad Stud'!!
Maybe it's 2 bad studs?
