toddu's Avatar
Replace accel pedal busing in situ
Well, I just went to install my new Rennline REV2 pedal, and find the gas pedal bushings are non-existent. All other bushings were replaced by PO (according to some receipts I read through), not sure why that one was skipped.
Anyway, need to order a rebush kit it looks like.
My question is, with the bronze kit, am I going to be able to get the new bushings into place without removing the pedal box? There is no other sloppy movement, just the gas pedal.
Todd
'81 SC
Old 08-30-2014, 09:16 AM
Wer bremst verliert
JohnJL's Avatar
What? The accelerator pedal on an 81 is a plastic/rubber hinged piece with no bushings.
Post a pic pls?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-30-2014, 09:33 AM
toddu's Avatar
Not the pedal itself, down at the cluster where the rod from the pedal and the accel rod down to the transmission bell crank meet.
Todd
'81 SC
Old 08-30-2014, 09:39 AM
I did my '87 with a Rennline replacement accelerator. No bushing required. Post pics if you're having difficulty.
Good luck!
Old 08-30-2014, 09:41 AM
Just saw your last post. There should be helper springs to take up the slack both at the pedal itself and at the throttle body I believe.
Old 08-30-2014, 09:43 AM
toddu's Avatar
Pretty sure there is a bushing in there on both sides (well, supposed to be, mine is missing). Here -
The whole thing I'm holding wobbles about a quarter of an inch.
Todd
'81 SC
Old 08-30-2014, 10:11 AM
Bollweevil
When the accelerator bushings fail, no springs are going to help. When my accel. bushings failed I was running up through the gears entering the interstate and the throttle was stuck at WOT... an interesting experience as the accel. pedal just flopped around.
Even if the prev. owner replaced the other bushings and not the accelerator (which doesn't make a lot of sense) it might not be a bad idea to go ahead pull and replace all the bushings in the cluster.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Bollweevil
Todd
Todd, you can tell by looking that the bushing has disintegrated, there should be no free play. No idea if you can replace it without pulling the cluster however.
Jack
74 911 Coupe
Old 08-30-2014, 10:14 AM
toddu's Avatar
Guess I'll order and try. No worky, my 20 minute Rennline pedal replacement will turn into a much longer job.
Todd
'81 SC
Old 08-30-2014, 10:18 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, you need the bushing there. it is tight but it can be done in the car. If you remove the seat your body will thank you Also re-check your throttle play to insure you get full throttle after replacement, it may take up or loosen your slack.
'85 Carrera Targa
PCA/POC
Old 08-30-2014, 10:51 AM
Patience and being careful will get you through this. It's really not that difficult to do it in the car. Take care with the cotter pin when you pull it, get all the bits of the old bushing out, press the new ones in with your fingertips. Lube the shaft.
The Cap'n
Old 08-30-2014, 11:00 AM
Walt Fricke's Avatar
+3 or 4 on being able to do it in the car. Never any fun working down there, but doable. Saves lots of time.
Old 08-30-2014, 11:14 AM
1QuickS's Avatar
I did'em in situ...
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 08-30-2014, 02:12 PM
gwinnch's Avatar
Working on the same thing for my 85 last night. Throttle not opening all the way, so I'm checking all the plastic bushings starting at the accelerator-one side of mine was totally gone. I bought a $4 small diameter brush at the hardware store and ran it in there to clean it out before I pressed the new bushings in. Hope to get back on it this afternoon.
What should I lube the "ball & socket" joints with, bearing grease?
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 08-31-2014, 08:52 AM
toddu's Avatar
Just purchased bronze ones this AM myself. I know they'll be harder to press in, but hopefully they won't be too tight to squeeze in with a C clamp or nut/bolt and some washers to press in.
Todd
'81 SC
Old 08-31-2014, 08:57 AM
gwinnch's Avatar
I bet the bolt & washers would work. Take a look at the tunnel side of the tube with a mirror if you can. My tube had a slight burr on it, didn't worry about it with the plastic bushings but if you have one it might keep the brass from going in square...imho
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 08-31-2014, 09:25 AM
DRACO A5OG's Avatar
Don't worry the brass ones slip right in, the pita is get the ball end cap off, use a small vice grip, hold it straight and push back until it pops off.
I found it better to disconnect at the bell housing to allow less load on the linkage while you are working on it.
'85 Carrera Targa
PCA/POC
Old 08-31-2014, 10:20 AM
DRACO A5OG's Avatar
Whoa, is that black rubber piece OEM?
Originally Posted by gwinnch View Post
'85 Carrera Targa
PCA/POC
Old 08-31-2014, 10:22 AM
DRACO A5OG's Avatar
Nevemind, it sure is. looks like a bushing in the PAG diagram. 901-423-193-00
'85 Carrera Targa
PCA/POC
Old 08-31-2014, 10:33 AM
gwinnch's Avatar
I ended up cleaning the hard black stuff out of the sockets and putting in some lithium based multi-purpose grease with moly as the top "ball" for the pedal linkage was galled.
Checked my throttle after and it seems to be opening all the way now. First test drive last night I could tell no difference in the performance, but it was a short one. Second drive this morning was 90 minutes and felt a little zippier...
Does the '85 Motronic have to relearn anything since the throttle is now opening completely?
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 09-01-2014, 01:31 PM
