Certified Pre-Owned
BGCarrera32's Avatar
Question Ever done front Bilstein inserts into BOGE struts...?
1) The Bilstein inserts ship with this rather thick rubber sleeve/o-ring thing (bout' 5/8" in diameter, 3/16" tall) under the big nylock nut on the threaded shaft, above the big dust cover can. Does this rubber piece get discarded or used somewhere??? Not obvious to me why I have it...
2) If I replace my ball joints while I'm in the area...does the car need to be realigned...(yes I'm a newbie at this)...?
Any tips/info appreciated...!!!
-BG
'84 Carrera Coupe
Old 10-02-2002, 07:46 PM
makaio's Avatar
Can't help you with # 1, but yes on the alignment.
Old 10-02-2002, 07:50 PM
Chris Lovell's Avatar
Discard the rubber bushing. Alos, there is not big rubber slam stopper that fits over the strut shaft as you'll find on the Boges. Just the straight shaft held up by the the nylock nut.
CWL
'88 Carrera Cab
Old 10-02-2002, 08:28 PM
I figured the rubber washer was just to hold the dust cover on the shaft for shipping purposes. I tossed mine and everything works fine.
Argo
88 Targa
Old 10-02-2002, 09:16 PM
Certified Pre-Owned
I thank you kindly for the answers....
'84 Carrera Coupe
Old 10-03-2002, 06:18 AM
