Blank case question
So I have a car with a blank case engine, but it has a type stamp- in this case, 911/51, which according to my reading of the Red Book, is a 72 t case. The casting bus where the engine number should be looks completely clean- no grinding marks or anything- just casting surfaces. I have someone telling me that a blank case from the factory would never have an engine type stamp, that it would be completely blank. Really? How would anyone know what specs it was set up for? Can anyone clarify this for me?
Much thanks in advance!! |
Well, I have heard the same thing - if you got a replacement case it had no SNs.
You don't need the SN - the type number tells you all you need to know (plus I don't think there were any differences in the cases themselves - it was cranks and heads and rods and pistons and cylinders and intakes and maybe exhausts which created the different engine models). Perhaps the same is true if you purchased a whole new motor? Again, the type number would let you know what the innards were. |
gearhead
When I worked for Carquip Tom had 2 NOS 2.0l mag case replacement cases. They came from Karl Thompson who got them from Vasek. They were both stamped 901/16 but no serial numbers.
83 911 Production Cab #10
As per the facts in the posting below.
Case close ![]() ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I can confirm, my new case (930 Turbo) has no s/n and also no type number.
BTW, its beautiful. Dennis |
Autocross/Hillclimbs
my case is stamped 930/06 (78-79 3.0), and the other marking is *3280888* which would be from like a 60s engine.
all i have are guesses as to why. theyre factory stamps, aluminum case, and under the "/" it appears to have a "9" that looks as if something was not ground all the way off or something before restamping with 930/06. I have a feeling some of the things that went on, we may never understand ![]()
2x 1984 944 N/A; 1988 951S Silver Rose; 81 VW Rabbit Diesel; MK4 VW R32
President - Bridge City Autosports http://www.bcautosports.club |
Generally however, a replacement case has no serial or type # because it is an empty case, so it could be built up as anything. It would be interesting to know the "-xR" casting part #'s on the sides of the case since this gives a clue as to the production period.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Thread Tools | |
Rate This Thread | |
