Been thinking about your issue, and considering you geographic hinderances, for power and speed you've got the answer in your username. Taking Steves comments in consideration, i would lean toward keeping it stock disp. Get the cams, carbs,and exhaust. Have the heads worked,get your distributor recurved and enjoy it for the reason,i assume you bought it,having an aircooled 911. Hell you might have $$ to freshen the trans too.
Gator 99 996 c4 |
Since my cylinders are alusil, it is recommended I replace them either way. If I am paying for a new set, any good reason why not go for the 3.2?
'09 997 GT2 '86 911 3.2 '83 911 SC (work-in-progress) |
I think 3.2, cams, SSIs and keep the CIS would make a nice powerful reliable SC
The cost of getting speciality air cooled 911 work done in the US is way below what you would pay elsewhere (UK / EU / Australia! ) and the quality is most often excellent. This factor should balance out what you may pay in shipping. As you need to do something with cylinders anyway, I would shoot for a 3.2 setup. Get JE pistons to suit - at least 9.5 to 1 . Your connecting rods may need 2 sorts of machine work, the little ends may need to be rebushed & maybe drilled offset as the 3.0 & 3.2 rods are different lengths. Then your rod big ends will need refinishing, especially if you use ARP rod bolts (recommended) . I would also replace your CIS unless you can find a local who can troubleshoot the system. There is a lot of cold weather plumbing in CIS that you will never need. You have also mentioned 964 cams, Head work & PMOs. So in your situation I would try and find a US shop who could coordinate things for you. Good luck with it Peter 78 3.0 SC |
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold |
3.0 rebuild
If you are going to the cost of building a 3.2SS, why not get the 100mm pistons and cylinders? They don't cost any more and will give you a bit more displacement. Also, there is an old saying "horsepower is in the cylinder heads". A few bucks more spent for a set of heads with larger ports will go a long way towards giving you a powerful engine. And, by adding the twin plug ignition, you will be running much less timing advance (25 degrees vs 36 degrees) which will help reduce engine heat and allow the engine to run more comfortably on today's gasoline. And, if you choose to go the direct fire ignition route, you will eliminate the distributor (no caps and rotors to buy) and have adjustable timing! The combination of displacement, good heads and reasonable cams should give you a great street engine. If you build the 3.2 or 3.3 engine and keep the CIS (for now), it will be much easier at a later time to remove the CIS and add PMO carbs or ITBs. There are so many things that can be done, but it really depends on how you want to use the car. Street? Track? Autocross? Make the decision and then build to suit!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Black and Blue
I would get the PMOs just for the bling factor! To save some money, you can get your alusil cylinders replated in nickasil to stock diameter. I had mine done at EBS and ordered the JE pistons to match. The price is right also, call Don at EBS, hes the man.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Slippery Slope Expert
Pardon my ignorance here, but since I am at this getting rid of the Allusil crossroad, are the 3.2 P/C sets a "Plug 'n play" situation or is machine work required on the case/heads?
In that case ,no.
Gator 99 996 c4 |
Cylinders
Sort of depends on what cylinders you use. I chose to use the LN Engineering 100mm slip fit cylinders that fit the existing spigots in the 3.0 liter block. The heads that I used were a set of Carrera heads that matched up well with the tops of the cylinders. While the LN Engineering cylinders were not cheap, using them did save the cost of some machine work.
After reading all that I want both a 3.2 and carbs.. my wife will be mad
![]() OK, for arguments sake, lets assume I decide to go for 3.2 JE pistons 9.5:1 with matching cylinders (options?), 964 cams, and headers (since I don't need the heat). Along with that, get my heads and rods worked on. What shop would you recommend from experience? someone who can coordinate all this for me? I'd rather not deal with multiple vendors for obvious reasons. If I get a quote for all the above, along with the new fuel lines, new harness and new oil piping with upgraded oil cooler and all other replaceables and still feel like I can afford to get the carbs then so be it. If not, then I'll probably do that as stage 2 next summer when its too hot to drive the car anyway. We have a good mechanic who can troubleshoot CIS if worse comes to worst. The carb setup looks so good
Where are you geographically? They may help recommend a shop.
Todd
'81 SC |
ROW '78 911 Targa
He is in Bahrain, if I remember correctly.
Not too many local resources.. ![]() Sent from my iPhone using Tapatalk
ROW '78 911 Targa
Put one of these on whatever engine you decide to build...
http://www.rothsport.com/Products/Engine/Fuel-Injection-Systems/FI-Systems.htm Sent from my iPhone using Tapatalk
part of the budget is already earmarked for an awesome custom harness from Dennis so don't blame me for not getting carbs ![]() If I'm shipping to the US, I can ship to any state
I'll leave this for stage 2
ROW '78 911 Targa
![]() I would like to go to independent throttle bodies at some point and with Rothsport just up the road from me, I have been there and seen most if not all of their intake systems. Very nice stuff to say the least.
Do these carb kits, such as PMO or weber, come with their own fuel lines or would you need to get custom lines? what kind of work goes into changing the engine harness?
What is the real life benefit of going for ITBs?
ROW '78 911 Targa
The fuel lines are just standard lines rated for ethanol here in crappy gas land. Low pressure for most systems regulated down. Any wiring harness would be application specific depending on controls used.
Benefit of ITB 's was explained by Steve. Throttle response and total HP improvements. With EFI even more. Lots of threads here on Pelican documenting installing all types of different intake systems. Sent from my iPhone using Tapatalk
My friend has installed PMO ITB carbs on his rally/targa 911SC.
He now has rapid throttle response, the engine responds instantly to the gas pedal similar to a motor bike (japanese not HD!!) . The CIS system is/was very good for the era as it balanced out various requirements such as emissions and economy and the demands of everyday suburban driving in all climates. My friends PMO car takes a minute or so to settle down after a cold start, its petrol economy is way less than with CIS, but it is now very very sporty. I also agree with Fred Cook regarding the 100mm pistons and cylinders. Especially if they don't cost any more and will give you a bit more displacement. Peter 78 3.0 SC |
