A/C: no power to compressor and condenser fan
AC has worked great for 9-10 years. 911sc 1981 us spec with factory a/c.
Yesterday I hit it on and evaporator fan runs as usual but no compressor kick in and no condenser fan. Evaporator fan runs at all speeds but no power at condenser fan or compressor. Rotated temp knob and nothing. Tried swapping out round black relays and they all appear good. No popped fuses at first glance. Any tips on where to go next? Relay in smugglers box? Thanks, Scott
Scott 1981 911SC Targa - Platinum Metallic |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
The relay closest to the front of the car runs the condenser fan. Then check the relay in the smuggler's box. Then the connection at the compressor. (green wire). Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Scott... I've experienced no system power at all and it was a stuck relay in the smug box. A few taps on it and power on. So... if you have evap fan power I would guess it not being relay in smug. Have also had compressor shut down. Don't recall if front blower went down when this happened. Diagnosis is: #1) jump the solid green and green/white wire connected to the thermostatic switch... if power on, bad thermo switch. #2) If you have a pressure switch, jump that. Not sure that that would effect your front blower but would definitely shut down your compressor. (Problem I experienced was a pressure drop and pressure switch worked as it should. Disregard "Risky" note.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Karl,
When are you sending the royalties check? |
Monster you created was waiting for you to show up
You send me check. (Frankenstein need scarf --- AC too cold now. ) Credits: you did send me schematic... but who decided jumps? The noob! FYI Scott, Kuehl = ultimate Porsche AC wisdom. Listen to him. Be sure to follow instructions... or you'll get beat up. Am outtahere now --- West and his tag team killer company are surly due any moment now.
Banned
[QUOTE=Discseven;8251213]
FYI Scott, Kuehl = ultimate Porsche AC wisdom. Listen to him. Be sure to follow instructions... or you'll get beat up. Am outtahere now --- West and his tag team killer company are surly due any moment now.[/ I'll start with fuse removal/inspect and check temp switch and A/C relay. Thanks all for getting me started and have a nice day I do like the Kuehl products though.
Scott 1981 911SC Targa - Platinum Metallic Last edited by schoward; 09-21-2014 at 04:54 AM.. |
Ac temp switch
Update : all fuses fine, compressor connection fine, and then replaced the a/c relay which did not nothing.
Frustrated, I thumped my finger aggressively on the ac temp switch knob and compressor clicked on and condenser fan came back to life. Need to dig into this switch now. I replicated the issue a few times so switch seems to finally be tired. I have read about the poor fitment of the new ones. Aside from fit, how hard are these to swap out? Do I have to remove the old and resnake the new temperature sensor wire or can I keep my existing and connect to new switch?
Scott 1981 911SC Targa - Platinum Metallic Last edited by schoward; 09-21-2014 at 04:59 AM.. |
Alternatively:
In '58 the USAF supplied me with 2-3 of these for burnishing/filing relay contacts on B-47's and KC-97's. For many years after I always kept a few in my field service kit. Use one to "clean up" the switch contacts and then add a relay to indirectly power the clutch circuit. Switching such a high current indicative load as is the clutch coil is a "dirty" business, best left to an easily replaceable relay contact pair. While you're at it the addition of an LED light to indicate compressor cycling rate might be a good idea. But keep in mind that the inductive "kick" upon opening the inductive clutch involves a LOT of power, so a resistor/LED, POWER LED, is advised Switch Contact Burnisher/File [BURNISHING TOOL 1/4 INCH] : Pinball Magic, Your Pinball Resource
AC on a 72T...can't get power to the solenoid side of the relay in the smuggler's box. If the relay is manually closed, the compressor clutch and fan work as they should. Just can't get the fan speed knob to actuate the solenoid.
Any suggestions? |
