My Refinished Fan
I got my fan back yesterday from Flying Jay. It looks pretty good.
I had already ceramic coated the housing in cast iron gray and Jay bead blasted and clear coated the fan in a matt finish. He also re-plated the hardware. I had previously polished the fan but I could never get it perfect as there are too many dings from 40 years of driving.
Won't be much longer before the car is driving again.....
Old 09-13-2014, 01:38 PM
Banned
Wow. That looks great.
OK, the questions that are on my mind - where, and how much?
Old 09-13-2014, 02:08 PM
The ceramic coating on the fan shroud was done at a local powder coater - it was $70 and they used a product called CeraKote. I also did the valve covers in the same finish.
The fan refinishing was done by a guy here on pelican, search flyingjay - it was $135
I'm probably going to replace the strap around the shroud with the stainless version that is sold here on the site by Rennline. The gold plate doesn't seem to match as well as it used to. I will try cleaning it up first.
Old 09-13-2014, 02:36 PM
Great look Vern. I'm kind of a noob, and you've probably discussed this in detail before, but what is the fuel system you have on that beast?
Michael
Mike
'87 911 Cab
'82 931
'74 911S Coup
'69 912 Coup
Old 09-13-2014, 05:25 PM
Michael
I am in the process of changing from stock CIS to PMO electronic injection with individual throttle bodies. To run it all, I am using Electromotive GT engine management. I purchased everything as a kit from Clewett Engineering.
When I'm finished with this project, I will start a thread with lots of photos but if you want a sneak peek, my inspiration started with this thread... My PMO ITB Project
Old 09-13-2014, 07:07 PM
Banned
Very nice. Thanks for the info.
Old 09-13-2014, 07:10 PM
Discseven's Avatar
Nice Vern!
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 09-16-2014, 06:18 AM
Brew Master
cabmandone's Avatar
My brother is working with what looks like the same setup. He has PMO's with Electromotive ignition. He's fighting with the float setup right now but it should be very nice when he's done. Your engine looks NICE! good luck and I hope you get it in and running without any trouble.
Wooooooooo cowboy! That's a fuel injection system. Nice! My brother's car is carbed.
Old 09-16-2014, 07:28 AM
Banned
PMO ITBs are gorgeous. But the cost is breathtaking. Hmmm, maybe if I win the lottery...
I guess I'd have to buy tickets first.
Old 09-16-2014, 08:17 AM
fritzgator's Avatar
Wow thats clean! In that 1st pic i thought the engine was in the car and you had some kinda crazy cage over the electrics. Inspirational.
Gator
99 996 c4
Old 09-16-2014, 08:33 AM
Beautiful engine! Thank you for sharing, I will be sending my fan to this fellow Pelican in the future.
Anthony
'71 911E w/ MFI
Old 09-16-2014, 09:19 AM
That looks so good I would definitely delay putting it in a car so I could just stare at it a while.
Matt - 84 Carrera
Old 09-16-2014, 10:00 AM
Thanks all....I may have to start checking my oil at the gas station
Old 09-16-2014, 11:21 AM
