disband
juanbenae's Avatar
can I see oil vent catch cans
for those of you that have gone to carbs what are you using for the crank case vent bottle? photos woul;d be great. not adverse to drill holes any longer so that will work.
let's see what you've done.
Old 02-26-2010, 11:33 AM
AutoBahned
RWebb's Avatar
search here & on Early 911 bbs for dozens of photos
include the term "breather"
Old 02-26-2010, 11:59 AM
sjf911's Avatar
I don't have carbs but an EFI turbo. I originally vented into the engine compartment but the fumes sucked into the heater were too much. This winter I ran a hose parallel to the AC suction hose and vented under the car next to the starter.
Before:
After:
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-26-2010, 12:40 PM
Happiest when Tinkering
gsmith660's Avatar
I dont even have a catch can just a filter.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 02-26-2010, 12:41 PM
AutoBahned
RWebb's Avatar
on the threads you find, pay attention to Grady's comments (as usual)
e.g. the hose to the can wants to be big - the one in pic #1 looks to be too small to me
Old 02-26-2010, 01:08 PM
PCA7GGR's Avatar
here you go:
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 02-26-2010, 01:45 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Why aren't you venting the crankcase to the oil tank and then venting the tank with a catch can/breather? Even the hardcore racers that install a front trunk-mounted oil tank vent the crankcase all the way up to the tank and then vent the tank with a catch can w/breather.
Kevin L
'86 Carrera "Larry"
Old 02-26-2010, 05:48 PM
Czar of C.R.A.P.
dfink's Avatar
I made mine out of an old A/C receiver dryer. I gutted the insides, made a hole in the end for the filter and used PVC connectors. I had the guy at the parts store look around for curved hoses till we found one that would work. The engine vents to the oil tank then this vents the oil tank. The small line is there simply because I didn't have a fitting to plug the hole so I just put a line on it and and it also goes to the oil tank PCV connection. I got the reciever for free from the scrap pile at a radiator shop.
Forgot to mention if you do this put the hole for the filter in the other end.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 02-26-2010, 06:52 PM
Czar of C.R.A.P.
dfink's Avatar
Also when you blow your front crank seal at 7000 rpm all over the nice shop owners pretty dyno because you left the restrictor in the used hose because to tight to buy a new one, you quickly find that a new vent line of substantial size is a good investment..
66 912 Coupe
Old 02-26-2010, 06:57 PM
sjf911's Avatar
LOL, I forgot to remove mine. I actually blew the crankcase vent hose off at the oil tank at about 6000 rpm on the steady state dyno and it acted like a fire hose spraying oil 20' behind us. Not much got on the dyno but the bay floor was a mess.
Sapere aude
Old 02-26-2010, 07:37 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
i installed one of these
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-26-2010, 09:16 PM
1984-911 M491
Trog's Avatar
Water bottle solution:
1984-911 TLC......SOLD
Old 02-27-2010, 05:24 AM
gsmith660's Avatar
plastic or aluminum? Intresting idea
Old 02-27-2010, 05:27 AM
1984-911 M491
Trog's Avatar
Aluminum
Old 02-27-2010, 07:26 AM
gsmith660's Avatar
That is a good idea as catch can are way over priced and about the same size as the water bottle
Old 02-27-2010, 08:04 AM
brads911sc's Avatar
check out summit racing "breather tank". They have ones that are nice that start at $32.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-27-2010, 08:35 AM
disband
juanbenae's Avatar
good stuff, thanks!
kevin, it should have stated oil tank not crank case...... my bad
trog, is the heat in the motor area too much for the water bottle's plastic cap? has that passed race tech for nasa, pca or scca? i do like that idea a lot.
the summit units mentioned have 6 an fittings & i might expect that to be too small?? thoughts
Old 02-27-2010, 12:20 PM
gsmith660's Avatar
yep too small I would want 10 or 12 an
Old 02-27-2010, 12:27 PM
sjf911's Avatar
The SC OEM vent hose is 1" ID.
Sapere aude
Old 02-27-2010, 02:04 PM
disband
juanbenae's Avatar
thats closer to 16 AN ? is a single "AN" 1/16"?
Old 02-27-2010, 02:14 PM
