Send a message via AIM to fintstone
I recently had a intermittant, then no spark condition and after replacing almost everythng via swaptronics without luck, I broke down and troubleshot the problem. It turned out one of the wires (red, power) on the back of the six pin had not been crimped properly and just pulled out but was still held in by the rubber boot so it was not obvious and made some contact until it didn't.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-29-2014, 09:10 PM
Eva
911SauCy's Avatar
Originally Posted by boyt911sc View Post
911SauCy,
I work a lot with CIS engines and if I ever need someone to check my CDI, I'll send it to Ingo. Or send it to someone you don't know.
Tony
Why would I send it to someone I don't know?
Is there a website for Ingo, I G-Searched them and CDI in a number of arrangements but came up with nothing useful.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 09-30-2014, 05:32 AM
ROW '78 911 Targa
timmy2's Avatar
Just PM him?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-30-2014, 08:45 AM
T77911S's Avatar
Originally Posted by 911SauCy View Post
New random thought through reading...
Was reading on Perma Tune website. They say that if your coil goes bad, the CD box is destroyed...
True? (Just seems like that would "make sense" for them to say considering they're supplying new boxes.)
I am definitely going to buy a new coil, already got the multimeter.
Also, does the dist need to be removed to replace the trigger wire? Looks awfully close.
the bosch unit is very robust and very good.
a bad coil should not hurt the CD since its really jsut a capacitor discharging into a coil. you can have it rebuilt jsut for reliability but i think all that is replaced is the cap and a few SCR's for some more heavy duty ones if you will.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-30-2014, 09:27 AM
theiceman's Avatar
anyone have any specifics ofn this or is this one of those closely guarded secrets to stop DIY guys from spending a few bucks with a soldering iron over many hundreds at a specilist.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-30-2014, 10:17 AM
Do search here....all the information on the Bosch CDI is here.....what and how to replace stuff.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 09-30-2014, 11:08 AM
theiceman's Avatar
will do thanks
Old 09-30-2014, 11:33 AM
Eva
911SauCy's Avatar
Update:
With the help of Lovely Mrs Saucy, I was able to get closer to an answer last night.
First things first. In the 4 years I've had the car, I've never fiddled with the CDI box/engine compartment electronics. I unplug the 6-pin and this little 3 pin was just hangin out...not plugged into anything...what's it to? (looks to have a blue and brown wire?)
Then I was able to test the key on voltage at the 6-pin, all good at 12.24 Volts, ruling out bad ignition, wiring or fuse from battery.
Then, with engine cranking (lovely assistant) I tested the VAC across the left-most pins on the connector. (dist pulse shielding and dist pulse input) I was able to get a variable reading while cranking between .900VAC and .955VAC...does this seem right?
CDI testing instructions I found said that if there is no pulse the dist pulse generator is bad. If there is pulse it's likely a bad CDI or coil. Well I just replaced the coil so don't think that's it. However, the instructions kindly left out what kind of VAC reading should be expected.
I believe I've narrowed to the CDI, other thoughts?
Old 10-29-2014, 07:48 AM
pete3799's Avatar
I believe the 3 prong plug is for an external voltage regulator.
Pete
79 911SC RoW
Old 10-29-2014, 08:17 AM
Eva
911SauCy's Avatar
Well...the car seemed to perform/run just fine without it all of my ownership.
Perhaps I'm living in a fool's paradise...
Old 10-29-2014, 09:21 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The measurements on the coil output of the Bosch CDI box are not valid without connecting the ignition coil itself. The output is one side of a capacitor and a high-impedance DVM will get confused. You need a proper load and then the output is nearly zero (unless the internal capacitor is damaged).
Be careful, with a bad internal capacitor this output can produce dangerously high voltage with enough current to hurt you.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-29-2014, 10:46 AM
