Banned
Yes, I did. About 12 inches worth. I could have got away with less, but I wanted the transition to be very gradual. I could run 225/45s without problem, IMO. |
Go-Kart Mozart
Digital level attached to a piece of square tubing just long enough to run edge to edge of the wheel. Bungie cord the tubing and level contraption to the face of the wheel. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
TY Eric. I saw 225s on rear in post and now can't find. If anyone is running them... pls post pic. I just can't fathom 225 fitting.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Laser level I got... bubble. Thought for $19 it was good move. Now I see the light of digital - TY JAR. Just looked at Harbor F. They have digi level for $22.
I love harbor frieight... most of their tools are actually great. Make sure the level is accurate though. You are talking fractions of a degree here. Keep us posted!
Went out yesterday and did some gas-guzzling accells... I don't have sensitivity to feel the difference. Larger size does feel softer over all.
Setting aside equipment used to take alignment readings, here's tool list:
19mm sockets & wrenches - breaker bar, torque etc . . . 8mm Allen Socket for your torque wrench 12mm Allen wrench Anything missing? Thanks for link Ian.
Under the radar
One thing I found to be very important is the level of the floor. It needs to be PERFECTLY level from side to side where the tires sit. I used thin pieces of plywood under my tires to shim up my floor. You need to be within 1/16" of level from side to side or your camber measurements will be off. It is surprising how uneven most slabs are.
Under the radar
How much camber are you running and what spacers do you have in the front?
Go-Kart Mozart
Husky 9 in. Digital Level-THD9403 at The Home Depot
LJ... nice relationship of wheels/tires to fenders. Looks like you (someone) spent some time and knew what you were doing. 225 on front... interesting. Am talking with TirePlus guys about changing tire sizes for me so your post is timely. TY. (Nice pic!)
Home Depot $40 ![]() Harbor Freight $22
Wheels are 951 fuchs @ 16X8 ET23, toyo r888 tires. I have no spacers on the front, approximately 1.5 degrees neg camber (max with stock parts) , no AC lines, and rolled fenders. The above mentioned mods are definitely more than the minimum required to fit without rubbing. |
Went back to 205 / 50 front and 245 / 45 rears---guys at Tires Plus were very accommodating. Working longer than expected on AC. When done with that... am onto alignment.
My opinion...
I'd sell the 9's, buy a set of 7's and run 205/225 summer tires in a good brand. I think you'll find those tires to be junk. The car will drive a lot better and that's more important than how it looks sitting still, right? JR |
If 7's on the rear of an SC work for you JR, I'm all for it for you. My foolish taste doesn't accept it. Seems to me an SC's azz-end needs a touch more substance to fit the space. Aren't we 911 admirers because of, at least in part, 911 design? Definitely not claiming to be the correct interpreter of what should be--am firm believer in what floats one's boat does not necessarily float another's. What I'd like to do is get out of the 16's... and go to 17's.
I thought you had 8's and 9's. If you have '7's and '9's, my advice would be to swap the 9's for a set of 8's.
For me, it's less about how it looks than how it works. Larger wheels have a downside, which is weight and (usually) a higher moment of inertia. Makes the car slower... I actually run 7&8x15, which is lighter yet. JR |
Am running 8s and 9s x 16.
