Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
![]() There's additional degradation due to weight further from the axis of rotation but it's difficult to quantify w/o a dyno
OMNI Brake and Alignment, four two five 823-1511 Off of 2001 C4, 18", factory standard. |
Go-Kart Mozart
Someone mentioned the Scruggs pamphlet. Well worth the time to track down a copy. It helped me a great deal. I've completed exactly one home string alignment and 20k miles later I'm still seeing nice even tire wear. Strings can be tedious but if you are careful and diligent you can get your setup just as good as a high dollar machine.
Another tire option is out there now. Toyo Proxes T1R is back out in 245/45r16. The hitch with the T1R is the front. Front option is 195/55r16. You'll lose half an inch in section width and height. I'll stick with the RE-11s. I've gotten almost 18k out of the rears (they need replacing) and the fronts have a ton tread left. FWIW my alignment specs are close to what Pete Z recommends. Daily driver with some hooliganism thrown in. Front - 1/16" total toe in. / .6 degrees negative camber. / caster around 5.8 Rear - 1/32 - 1/16" total toe in. / 1.2 degrees negative camber.
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Under the radar
A couple of things. Negative camber may increase IF you have worn strut inserts or other worn suspension components. Bent struts can make the problem worse as well.
The lower the front goes, the more negative the camber. There are offset ball joints, not sure if they can make more positive camber. On my '71, I used a strut brace to force my shock towers apart. I was able to get zero camber with my car lowered.
Insert Tag Line HERE.....
245/55? That's a Nascar tire! Huge! I had to run 245/50s once and it looked way out of place.
Flat Six
Don't forget that the taller rear will increase forward rake, which effectively lessens caster . . . .
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Interesting chartographics Bill. TY. Have not been out yet since this realization so am curious to see if I can sense it.
TY for specs you're running JAR. Am curious how you DIY calculate "o.6 degrees neg camber?"
TY for input Flat. Neg ramifications of larger tire size... definitely increasing. Am pondering the evil I have done.
Under the radar
Make SURE everything is TIGHT on your front suspension. I once found I had a loose wheel bearing and that made it seem like I had negative camber on one side. A loose strut insert can cause the same effect.
Schleprock
Toe is easy with a set of toe plates from Longacre. Here's the Scruggs book. Send him some money as a thanks.
Toe Adjust Techniquest How does the 205/55 look/fit on the 16x8 front? 205 on an 8 in. wheel is stretching that tire a bit. Typically a 205/55 is recommended for a max wheel width of 7.5 in. I am willing to bet your front toe is currently a mess with tires that have inboard shoulders like you show. That inner shoulder wear is typically not what an old 911 will show. These old 911s have one heck of a time getting any decent amount of negative camber. Tires that look like that either have a boatload of negative camber or a ton of toe-in. So I suspect that is toe related or a badly bent strut. I've tracked 911s with a group for about 10 yrs and the stock-ish ones always have a ton of outer shoulder wear on the fronts, with not a lot of inner wear. My point of mentioning the track driving is that it accelerates tire wear and shows you what kind of wear you could expect to see after several thousand miles of street driving.
Kevin L '86 Carrera "Larry" |
Barring any wild deviations from stock, proper alignment specs are always going to be a moving target and driver specific. The stock Porsche alignment specs are designed around reasonably spirited street driving. Drive like a Grandma or some aggressive canyon work or spirited track use and poor tire wear will result. Uneven tire wear is the nature of the beast for a sports car. If your getting more them 10k miles out of a set of higher tread wear street tires on any Porsche with a factory alignment, your doing ok.
You can back off the specs for longer freeway tire life but when driving spiritedly, performance will suffer. There is no magic alignment setting, it is all about matching it do the drivers requirements and the rest of the suspension set up. That said, bent struts are a common thing and may be a cause of not being able to achieve alignment goals. At typical ride heights with un-bent stock parts, between 1 degree negative and 2.5 degrees negative appears to be the normal range most cars can achieve. Ride height, bushing age/quality, and chassis differences affect on which end of the scale any particular car falls and/or ability of exceed the boundaries of this range. |
Am having to eat my rear tire size as given. It's not 245 /55. It's 245 / 50. You guys must have thought me insane with the 55.
My Bad. My apology. Here's front/rear size confirmation. ![]() Went back to TirePlus today and asked what their "policy towards a customer who didn't like their tires was?" They said they'd replace all provided I bought the replacements from them. Damm nice. They got a new, dedicated customer. Gonna sleep on it.
Banned
On my 16x8 + 16x9 combo, I have 205/55s on the front and 245/50s on the back. As it turns out, the speedo is dead, nuts on at all speeds up to 75 (the highest I went over a time course). But, as I have said before, not all tire makers measure their tires in the same way. My experience with Kumho is that they are narrower and have shorter sidewalls than the nominal size would suggest. The speed trials bear this observation out.
