Bye-bye 245 / 45 / 16... Hello noob alignment
245 / 45 / 16 nonsense is done. I know... they're still available IF you want to pay a small ransom. Screw that. For amusement, am going to run the most economical alternative (I can find) for 8" front, 9" rear Fuchs... we'll see how economy performs over time. And... because I can't get a "professional" alignment so tires wear evenly, will dive into alignment having never done it before. Am posting to get input on how to make alignment adjustments. First, some background for you...
Tires Shopped online... TireRack, TireThis, TireThat.... problem is once shipping, balance and install is added... online's no longer an economical road (as I priced it.) Alternative size am going with is 205 / 55 and 245 / 55. Fronts = $62 each. Rear = $82. Installed total = $371. ZR rated (149+ mph.) Some have put 225 / 45 on rear---now I'm wishing I had the guys load that up to take a look. http://forums.pelicanparts.com/uploa...1411495084.jpg http://forums.pelicanparts.com/uploa...1411496414.jpg Installed If you're highly sensitive to 911 dimensional relations, DON'T DO THIS --- you won't like it. Fronts are close to 1/2" larger diameter. Rears, 3/4" larger. So my lower... has just been raised 1/4" F... 3/8" R. Remember, tires are only a test. Real mission on hand is DIY alignment. Am covering tires as I imagine others may be thinking over 245 / 45 alternatives. (Good to bring your own stubby tire valves to shop or you can end up with way-too-longs.) http://forums.pelicanparts.com/uploa...1411494986.jpg Front = 8 x 16 Rear = 9 x 16 Inside tire wear = standard option that came with this car. Fronts have always worn out leaving good rubber on the outsides. Sometimes both front and back have done same. Regarding front, I've been told "toe is set right but camber will simply not go any more positive." (If that's the case... how bout compensating with toe?) Below is front driver's side tire. And alignment was done supposedly by professionals with the latest high tech equip. http://forums.pelicanparts.com/uploa...1411495495.jpg Rears did OK this time around. Still... they're wearing on inside... and I'm guilty of too high pressure. Am dumping rears early only because size change is front-to-rear related. http://forums.pelicanparts.com/uploa...1411495524.jpg Alignment Toe, camber, caster... I understand principles. But am total noob where making adjustments is concerned. Thought "string theory" was interesting approach but from what I've heard, it's a lengthy set up. So... to check track, got $19 laser level from Harbor F. For toe, am going with "under C" method I picked up from Peter Bull in Sweden. TY Pete. His photos... http://forums.pelicanparts.com/uploa...1411495831.jpg A look at my strut tops. http://forums.pelicanparts.com/uploa...1411497919.jpg As I know it, front-end toe and camber is relatively simple. Rear end... that's complete mystery to me. Not sure I really care about caster---steers fine. Am looking forward to front & rear adjustment input from you guys before putting a wrench to this. TY :) |
I am all for do-it-yourself and I know some folks get decent results with home alignment.
My question is why can't you get a pro to align the car with an alignment rack and get good tire wear? There must be someone in Miami that can do it. When I did my suspension rubber bushing replacement and tie-rods and shocks and so on I did a home alignment and got it pretty close. I drove it with the old tires for a few hundred miles and then had the pro do it with the proper tools, AKA an computer and laser on the alignment rack. My alignment was pretty darn close. Good Luck. |
How wide are your rear wheels? (They look like 16x8, but the pics are too small to be sure)
If you're going cheap, why not 225/50 16? That's what the factory used, it is the exact right height, looks right, etc. |
2 points to make...
1. Alignment to factory specification makes the steering to sensitive, constant attention required to stay centered in the lane. Tried several alignments, shops, before being advised that factory alignment was more for track use, constant attention is expected. Was advised that if I wished to drive relaxed the shop would deviate from the factory specs. Can put you in touch with my shop and maybe they will be willing to share their trade secrets. 2.,,,NOISE! I always peruse Tire Racks customer reviews in an attempt to find the quietest tires that also fit the other desirable parameters. Sometimes successful, sometimes not. Most times I have found that "quiet" tires only remain so for 8-10,000 miles. Had one tire manufacturer that acknowledged that my 8,000 mile tire set was so loud that they not only refunded my cost, they contributed an equal amount to my favorite charity, Seattle Children's Hospital. Tires are still in storage if anyone is interested. |
Do you have the ray scrugs alignment pamphlet? it will walk you through the rear. Its time consuming but doable. I think some one has posted a scan of it on pelican if you search.
keep in mind that your larger diameter rear wheels will cause your car's gearing to become taller, which could affect its perceived performance.
My mechanic in Denver (Jim at Eisenbud's) "solved" the problem I've had with inside front tire wear by slightly bending the front struts (apparently my front suspension was at adjustment limits too). Apparently a common solution for them and I've seen MUCH more even front tire wear since then with no perceived effect on stability/steering effort/etc. |
here's a comparison of 245/45 vs 255/5o x16 on a US 3.2 Carera http://forums.pelicanparts.com/uploa...1411508891.jpg I hope the op made a typo and is using 255/50 not 255/55, which would be worse yet |
What size are they? I might be interested. Very nice on charity :) |
Setting caster and camber is pretty easy. I Went and bought a digital level at home depot, 80$ or so. Setting camber was done by simply placing it against the rim, and adjusting. Easy as can be.
Castor was done by setting it against the front of the strut, with the wheel removed. Pretty easy also. Toe, not so easy... Bo |
Bo |
How have they attempted to adjusted the camber in the past when there is still the tar stuff on the strut top mounts? I suspect the store didnt even try, just like in my case.
Bo |
http://forums.pelicanparts.com/uploa...1411516141.gif There's additional degradation due to weight further from the axis of rotation but it's difficult to quantify w/o a dyno |
OMNI Brake and Alignment, four two five 823-1511 Off of 2001 C4, 18", factory standard. |
Someone mentioned the Scruggs pamphlet. Well worth the time to track down a copy. It helped me a great deal. I've completed exactly one home string alignment and 20k miles later I'm still seeing nice even tire wear. Strings can be tedious but if you are careful and diligent you can get your setup just as good as a high dollar machine.
Another tire option is out there now. Toyo Proxes T1R is back out in 245/45r16. The hitch with the T1R is the front. Front option is 195/55r16. You'll lose half an inch in section width and height. I'll stick with the RE-11s. I've gotten almost 18k out of the rears (they need replacing) and the fronts have a ton tread left. FWIW my alignment specs are close to what Pete Z recommends. Daily driver with some hooliganism thrown in. Front - 1/16" total toe in. / .6 degrees negative camber. / caster around 5.8 Rear - 1/32 - 1/16" total toe in. / 1.2 degrees negative camber. |
A couple of things. Negative camber may increase IF you have worn strut inserts or other worn suspension components. Bent struts can make the problem worse as well.
The lower the front goes, the more negative the camber. There are offset ball joints, not sure if they can make more positive camber. On my '71, I used a strut brace to force my shock towers apart. I was able to get zero camber with my car lowered. |
245/55? That's a Nascar tire! Huge! I had to run 245/50s once and it looked way out of place.
TY for specs you're running JAR. Am curious how you DIY calculate "o.6 degrees neg camber?" |
http://forums.pelicanparts.com/uploa...1411574307.jpg |
Make SURE everything is TIGHT on your front suspension. I once found I had a loose wheel bearing and that made it seem like I had negative camber on one side. A loose strut insert can cause the same effect. |
Toe is easy with a set of toe plates from Longacre. Here's the Scruggs book. Send him some money as a thanks.
http://forums.pelicanparts.com/porsche-911-technical-forum/97217-toe-adjust-techniquest.html How does the 205/55 look/fit on the 16x8 front? 205 on an 8 in. wheel is stretching that tire a bit. Typically a 205/55 is recommended for a max wheel width of 7.5 in. I am willing to bet your front toe is currently a mess with tires that have inboard shoulders like you show. That inner shoulder wear is typically not what an old 911 will show. These old 911s have one heck of a time getting any decent amount of negative camber. Tires that look like that either have a boatload of negative camber or a ton of toe-in. So I suspect that is toe related or a badly bent strut. I've tracked 911s with a group for about 10 yrs and the stock-ish ones always have a ton of outer shoulder wear on the fronts, with not a lot of inner wear. My point of mentioning the track driving is that it accelerates tire wear and shows you what kind of wear you could expect to see after several thousand miles of street driving. |
Barring any wild deviations from stock, proper alignment specs are always going to be a moving target and driver specific. The stock Porsche alignment specs are designed around reasonably spirited street driving. Drive like a Grandma or some aggressive canyon work or spirited track use and poor tire wear will result. Uneven tire wear is the nature of the beast for a sports car. If your getting more them 10k miles out of a set of higher tread wear street tires on any Porsche with a factory alignment, your doing ok.
You can back off the specs for longer freeway tire life but when driving spiritedly, performance will suffer. There is no magic alignment setting, it is all about matching it do the drivers requirements and the rest of the suspension set up. That said, bent struts are a common thing and may be a cause of not being able to achieve alignment goals. At typical ride heights with un-bent stock parts, between 1 degree negative and 2.5 degrees negative appears to be the normal range most cars can achieve. Ride height, bushing age/quality, and chassis differences affect on which end of the scale any particular car falls and/or ability of exceed the boundaries of this range. |
Am having to eat my rear tire size as given. It's not 245 /55. It's 245 / 50. You guys must have thought me insane with the 55.
My Bad. My apology. Here's front/rear size confirmation. http://forums.pelicanparts.com/uploa...1411599471.jpg Went back to TirePlus today and asked what their "policy towards a customer who didn't like their tires was?" They said they'd replace all provided I bought the replacements from them. Damm nice. They got a new, dedicated customer. Gonna sleep on it. |
http://forums.pelicanparts.com/uploa...1411600854.jpg http://forums.pelicanparts.com/uploa...1411600868.jpg |
| All times are GMT -8. The time now is 08:25 PM. |
