'73 911 T Targa
Points - Stock, Pertronix, HotSpark, Crane Optical
A while ago, on advice of a friend, I put Pertronix points in my car to see if it would resolve a missing problem. In the transaction, my tach stopped working. I'm getting ready to put the original points back in to see if my tach starts working again, but that set me to wondering what would really be my best permanent point choice. My car was originally a 2.4; re-built to 2.7; has Webers and CIS. I don't race it - Like most, I don't mind extra power, but reliability and drivability are my top priorities.
Any thoughts on the best points choice? HotSpark, Pertonix, Crane Optical, mechanical? |
Rennch on YouTube
I was having lots of ignition problems, and had pertronix installed. Upon the advice of Steve grosekemper, I switched back to points, and have to say , it definitely runs smoother. Would also love to hear others thoughts.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Points are the way to go although you'll hear from a lot of pertonix fans here. I installed a pertonix unit on my 74 and it developed a stumble at part throttle removed it replaced with points been fine for 10 years. A friend of mine had the same issue with his Corvette.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Your car has Webbers and cis, or did have Webbers, now has cis?
You are about to start the great ignition debate, grabbing pop corn.
72 911 Although it is done at the moment, it will never be finished. |
Taking it apart is easy
My car ran OK with points, but I switched to Pertronix out of laziness so that I wouldn't have to adjust and fiddle with the points any more.
Now the car runs OK with the Pertronix and I don't have to adjust or fiddle. Everything else (tach, etc.) still works fine, too. No issues. I can say that the car runs 'better', because it never gets out of adjustment, which was my only reason for the switch.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
'73 911 T Targa
Oops- serious typo on my part.
My cars has Webers and CDI Never had CIS. Quote:
Thread Tools | |
Rate This Thread | |
