i HAD to see why there were 4 pages on removing a steering wheel nut.
i wish i had those 15 minutes back. why couldnt that plate come off? there was a thread on removing the nut on the rear axle. that one was very long too.
You can take that several ways. Sherwood |
ah. you too have been sucked into the vast hole of darkness.
Diss Member
If you see a socket with a matte surface it is almost certainly an impact socket.
Normal sockets have a polished plated surface. Really cheap sockets are also apt to have thicker walls. Craftsman, Snapon, Mac, Proto, ... If you recognize the name it will be thin walled with good steel. As far as the using a "regular socket" on an impact wrench. You don't to it because they can break. But on a one off job like this, turn the air down and try it. If it breaks then you go get another socket, a breaker bar, and a buddy to hold the wheel. (Or try the buddy method first with...)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Still here
Where are the pics and vid of this ???!!! |
weekend wOrrier
Brew Master
You got to love this forum! This thread is funny as hell, but within there are good suggestions from everyone and some crazy stuff from others. When I removed my original steering wheel, I had no issues at all. I wanted a deep socket 27mm but at the time had a regular size 27mm socket, got an extension and got the wheel out. Put the new sleeve for the wobble and installed the Momo steering wheel with the extension. I think I was done in less than half an hour. Anyway this is gold!
U.S. Army Retired 85 Targa Guards Red ![]() 2018 BMW 530i M-Sport ![]() Personal Quote: "Do whatever makes you feel good"
did i see Porsche nuts
i have one at home ;-) ivan |
Troll Hunter
Leave it to Max to revive a thread just to bust somebody's balls.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Undocumented User
I'm trying to remove the ashtray so I can get at the steering wheel nut, can anyone help?
mc...
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
What happens to common sense?
This forum has been a great help to many of us DIY’ers. Unfortunately, it has also made some people to lose their common sense!!!!! Sugarwood insisted using the wrong thick wall 27-mm socket but I had successfully used a similar thick wall 27-mm socket from my impact set for removing the steering wheels of SC’s and Carrera 3.2’s gazilion times before.
You could use a thin or thick wall socket, 6-Point or 12- point socket as long as it clears the opening. The thick wall 6-point 27-mm socket shown in my picture was taken from a Sears Craftsman impact socket set with an OD of 38.2 mm. See pictures below: ![]() ![]() ![]() ![]() The first thing that should had come up to OP’s mind was why were people able to use a 27-mm sockets and mine did not work? What is difference between my 27-mm socket and theirs? What is the largest OD of the socket I could use? All these simple questions could be readily thought by experienced people or have good imaginations. But some might think these as rocket science (?). I believe common sense will be more than sufficient to over come such obstacle. My two cents. Tony Last edited by boyt911sc; 12-07-2017 at 11:19 AM.. |
Troll Hunter
Guys, the thread is two years old. Pmax is justing bustin'...
Still here
^^^ an attempt, my last I promise, to show the guy that by his own standards below, the lack of pictures of how he solved this is totally unacceptable.
http://forums.pelicanparts.com/porsche-911-technical-forum/979438-my-vintage-911-handles-like-dump-truck-compared-my-modern-daily-driver-17.html Sugar, would you agree or is this a case where mere words would suffice ? Last edited by pmax; 12-07-2017 at 04:19 PM.. |
Slippery Slope Victim
I like the pics of the sideways deep impact socket. Perhaps it was just ignorance, not knowing all that much about automotive tools. Glad the job got done. Now I'll go rest.
MikeČ 1985 M491 |
four freakin pages on this thread for how to insert a socket on a nut -----Unbelievable!
08 Aston Martin Vantage V-8 (6 spd manual) (DD) 20 Cayenne white-black/red (hers) 78 930 (heavily modified) 08 GT3 RS (white/black) (modified of course) 67 911S outlaw (sold) |
Almost as Unbelievable as criticizing a thread that's nearly 3 years old
1958 356A - Sold to a rust collector 1978 924 - sold to a sewing machine repairman 1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB 1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car |
Undocumented User
It's not criticizing! It's observational sarcasm, Jerry Seinfeld has a few hundred Porsche cars in climate controlled warehouses because of the art form. I say get in on the sense of humor action boy, it'll make your life more enjoyable.
