bcgreen's Avatar
Dash panel LED turn signals
Does anyone know if there is someone who has manufactured LEDs for the turn signals on the dash board? I have bought some LEDs for the instrument panel earlier this year that work great, but would like some for the turn signals.
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 10-21-2014, 10:54 AM
Undocumented User
McLaren-TAG's Avatar
There are issues with the flasher for exterior turn signals, I suspect the same applies for the bulbs in the dash. Besides they're the only ones that are bright enough to begin with.
Old 10-21-2014, 01:10 PM
bcgreen,
If you do a wiring mod to make your turn signal indicators flash like a '84 on Carrera, it can be done. You will also need to replace your flasher with a solid state flasher, a EP26 works great. You can find these on line or at some auto parts stores. If you look at the wiring schematic for your car, find the blu/wht wires that lead from the indicator bulbs, which go to the flasher (which grounds them to make the indicators light when the flasher operates). These wires will need to be cut, then attach a female wire spade and attach to a ground point (I used one of the available ground terminals on the back of gauge).
For the LED, I used T5 (#74) wedge square LED bulb, p/n 45356 (green) from ledlight.com. You can also get the flasher from there.
If you decide to change your rear turn signal bulbs to red LED's, then you are ready to go because of the solid state flasher installation. You can also do red LED tail lights and a white LED for the back up lights. I have not found an amber LED front turn signal bulb that looks good/brighter than the original 1156/1157 bulbs.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 10-21-2014, 05:07 PM
Uncertifiable!!!
Uwon's Avatar
Originally Posted by dap930 View Post
bcgreen,
Ifind the blu/wht wires that lead from the indicator bulbs, which go to the flasher (which grounds them to make the indicators light when the flasher operates). These wires will need to be cut, then attach a female wire spade and attach to a ground point (I used one of the available ground terminals on the back of gauge).
dap930,
When you cut the blue/wire leading to the bulbs, which side of the cut wire do you ground and what do you do with the other cut end?
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 02-20-2015, 06:17 PM
Banned but not out, yet..
RSBob's Avatar
PM ETarga, he is a Pelican and sells dash bulbs
Old 02-20-2015, 07:28 PM
Registered speed offender
78SCRSMAN's Avatar
...or you can buy them from Superbrightleds! ...and they are plenty bright!
Also, I've done the requisite wiring mod. You won't need an electronic relay if you aren't using LED bulbs in your exterior lights.
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 02-20-2015, 09:17 PM
Uncertifiable!!!
Uwon's Avatar
Originally Posted by Uwon View Post
dap930,
Johan
Bump.
Old 02-21-2015, 03:29 AM
Uwon,
The turn signal indicators Blu/Wht wires are daisy chained to each other and then there is one Blu/Wht wire that will lead to the flasher socket. The Blu/Wht wire that goes to the flasher is the one that needs cut and grounded. The other end of the cut wire (the flasher socket end) will not matter because by installing a EP26 flasher, that terminal is no longer used. You can insulate the end with electrical tape or a section of heat shrink.
-Dennis
Old 02-21-2015, 09:00 AM
78SCRSMAN's Avatar
Here is another thread discussing the issue...
I solved the LED indicator problem!!
Old 02-21-2015, 10:23 AM
Air Cooled
Craig_D's Avatar
Thanks for the link and the offline help!
Cheers,
- Craig_D
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 02-21-2015, 10:28 AM
Uncertifiable!!!
Uwon's Avatar
Thanks for the clarification and help Dennis and 78SCRSMAN.
Johan
Old 02-21-2015, 07:27 PM
