GT2BH's Avatar
Anything to be done to 915 while out?
While rebuilding the engine and generally refreshing the car, is there anything I should update/upgrade in my 915 transmission(while its out) which I can do myself? I already plan on replacing the shifter bushings.
'09 997 GT2
'86 911 3.2
'83 911 SC (work-in-progress)
Old 11-02-2014, 10:02 PM
Almost Banned Once
sc_rufctr's Avatar
Oil change?
You could replace the shift rod seal but it would mean taking the nose cone off.
Easy job but if it's not leaking I wouldn't mess with it. Even a slight weap is pretty normal.
I'd also take the opertunity give it a really good clean especially inside were the clutch lives.
- Peter
Old 11-02-2014, 10:20 PM
unless it is leaking, or grinding, or hard to shift, I would clean the outside, do an oil change, and leave it alone.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-03-2014, 01:55 AM
Bollweevil
I would take this opportunity to change the shift rod seal. MUCH easier to do with the tranny out of the car. Unless we (sc rufctr) and I are talking about a different seal, you just pull the old seal out and seat the new one, not necessary to remove the nose cone or anything else??
Over the years my slight weep turned into drips of transmission fluid on the garage floor.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 11-03-2014, 04:19 AM
kodioneill's Avatar
How many miles on the car/trans? If over 140,000 I'd take it apart and check the pinion bearing race in the case.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-03-2014, 04:42 AM
GT2BH's Avatar
I had a little grinding when shifting into first and sometimes I cant find third. The car has 115k miles and I have zero history on the tranny. I cleaned it already and I don't see any leaks anywhere. I already have a new 915 mainshaft seal (999-113-327-40-M30), is that the one you are referring to?
'09 997 GT2
'86 911 3.2
Old 11-03-2014, 04:50 AM
Discseven's Avatar
GT... my 2 cents:
Replace shift rod seal...
Replace throw out shaft o-rings (seals)...
Check wear on throw out shaft. If needed, rotate 180 degrees...
Clean and lube input shaft. Might be disagreement on what to use. Here, high pressure grease applied at "A." Antiseize at "B."
Cable retainer gone so drilled small holes towards outside of vanes for zip ties...
Replaced shifter coupling...
If filling from top... breather points away from flywheel.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-03-2014, 05:36 AM
Project Addicted
Not to hijack, but we have a 100K 915 that we have never driven. I supposed to be fine according to the PO but maybe while it's gonna be out a while, there is a more in depth look/check we should do?
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 11-03-2014, 11:49 AM
KTL KTL is offline
Schleprock
KTL's Avatar
While you have it out of the car, I agree the shift rod seal and the input shaft seal should be looked at closely.
Since its out of the car you can take off the tail case and look at 5th & reverse gear. If 5th gear has a worn synchro band (the friction band that does a lot of work to match speeds when you downshift) and blunted dog teeth, then I would be willing to bet you'll only find worse things if you go inside the main case. If curiosity gets the best of you, it's not difficult to remove the 5th & reverse assembly to get the main case off and look at the more important 1st-4th gears.
Peter Zimmerman's wiki how-to is a FANTASTIC resource to have in hand.
Porsche Wiki
Kevin L
'86 Carrera "Larry"
Old 11-03-2014, 12:01 PM
1980SCMan
Alan Lindquist's Avatar
Because I had one crack and deform, I'm sensitive to the release bearing fork. When it goes, gotta pull the motor. And for $130 (I think) it seems to be a reasonable cost to replace and not have to worry for the next decade.
But if there's time, is there a reasonable way to do NDT on this part?
Old 11-03-2014, 01:03 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Good suggestion. The release fork is indeed prone to cracking. Happens more and more as these cars continue to age. Can have a machine shop crack check/magnaflux it or have it x-rayed.
Kevin L
'86 Carrera "Larry"
Old 11-03-2014, 01:09 PM
Fleabit peanut monkey
Bob Kontak's Avatar
On my '81 915, I pulled the plate off of the side of the trans before sending it off for rebuild to inspect. Two of the three nuts that hold the Fork (#6) to the Shift Cover (#5) were loose. Not big loose but at least one revolution backed off and they were not applying torque.
I though that was causing the buzz saw noise when shifting into third but Mayo, the re-builder, said no. Pretty sure Peter Zimmerman, in another post where I mentioned this, mirrored what Mayo said. I had seen a post where someone said if the fork was loose it can cause strange and scary noises but appears it was not with our 915's. Plus mine was definitely wrong but not officially loose.
Still worth a look when trans is empty. Not sure why the two came loose to begin with but my trans had been worked on before Mayo worked on it. May have just been an oversight - several were brought to my attention during the rebuild.
1981 911SC Targa
Old 11-03-2014, 01:44 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Bob brings up another good point. That shift rod guide fork is prone to coming loose from the plate. A "racing trick" is to drill the fork mounting holes all the way thru the plate which allows you to nut & bolt the fork. Also recommended to loctite those fork nuts. They do indeed come loose more often than most people realize.
Kevin L
'86 Carrera "Larry"
Old 11-05-2014, 07:35 AM
