Zack
car-nut's Avatar
Does SC and 3.2 have a PCV valve?
Hello all:
I am trying to figure out whether the SC or 3.2 engines have a positive crankcase ventilation (PCV) valve. If so, where is it hiding?!
Thank you!
Zack
The car-nut!
2007 Porsche Cayman-S
1982/86 wide-body 911 Carrera
1959 Triumph TR3
2004 Harley Davidson Deuce
Old 12-03-2014, 04:46 AM
Not really. The crankcase is vented back to the oil tank. Not many cars on the road have a dry sump setup with a oil tank in the fender. No real need for a PVC valve.
Old 12-03-2014, 05:56 AM
KNS KNS is online now
What he said, One of the nice things about a dry sump engine. No need for a PCV valve, CCV canister or AOS (failure prone on the watercooled 911s) to worry about, just a rubber hose going to the oil tank.
Kurt
Old 12-03-2014, 06:47 AM
Zack
car-nut's Avatar
Dear Glen and Kurt:
Thank you very much for the clarification.
Zack
The car-nut!
1959 Triumph TR3
Old 12-03-2014, 09:15 AM
The 3.2 has a PCV next to the oil fill but the 3.0 doesn't
Lorne M.
83 SC
Old 12-03-2014, 10:36 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Lorne M.
+1, the part is available at AutoZone ( Sorry host dos not carry this )
'85 Carrera Targa
PCA/POC
Old 12-03-2014, 10:44 AM
Just to add, in the later cars, the crankcase ventilation changed somewhat. The older 911's vent to the oil tank and then back into the air cleaner. The later cars had an electronic valve that vented (I think) back into the engine until it warmed up and then vented into the air cleaner once operating temperature was reached. Someone may correct me if I got that wrong.
Old 12-03-2014, 10:45 AM
