ac idle up switch
Hi Gang,
I have a 1976 Porsche 912E that I have installed an air conditioner on. It works fine except for one thing.......everytime the compressor kicks on, the engine rpms drop by about 200 or 300 rpm's. I am seeking a vacuum swithc that I can wire into the compressor so that every time the compressor gets a signal to turn on, it will create a vacuum leak, therefor causing my idle speed it increase. Does any body have any ideas on this? Please respond to jeffgill1120@gmail.com |
Sprocks... it's normal for rpm to drop when compressor kicks in. Any specific reason you don't want to let it be?
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
You could put a solenoid on a vacuum line that runs from before the tb to after the tb. It would be like a mini AAR. Kind of seems like more trouble than its worth though.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
When you remove the oil filler cap the RPM drops....
![]() You need to move the throttle plate in order to raise the engine RPM |
There are a few ways to raise the idle RPM's when the compressor clutch engages.
It can be an annoyance at idle, however I had a 73T 911 with carbs and it idled just fine at 550 rpms with the compressor clutch engaged (can't say it was a rocket pulling onto a highway though, lol). What are you using for engine fuel/ignition management, Bosch L-Jetronic? |
+1 on dos531 solution, that was the std way to bump the idle, it's simple if you already have ports before and after the butterfly. an idea is to use a fuel cut off solenoid from a carburetor,
but still need a needle valve to adjust the amount of air and set the idle speed. Now if you had a 3d printer you could make a custom valve holder with said provision....... ...the smaller the engine the more you need idle bump, how do I know? I put a decent a/c into my Fiat 128 wagon decades ago (with the BIG 1300, not the 1100 engine). hehe
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
