Broken Console on back of engine.
I find this part rather expensive, and thats even if you can find one.
During my rebuild I found the flanges broken off that attaches to the tinwork, mostly rust and stress. Anyone have any success in repairing these ? I thought of finding some small pieces of metalwork, constructing a new flange and either drilling and rivetting. Maybe even get it spot welded if i can. Any thoughts ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Ice, seen several on ebay. About 125.00
John "Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage |
Yeah i just found the one on ebay .. busted up one posted a few times . im in no hurry, and was just wondering if anyone has ever attempted a repair or just got a new one.
Once a friend of Cliff
contact parts heaven in hayward ca.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
will do thanks
I successfully brazed one onto my original one. Luckily I had a spare which had the side I needed and was missing the other side.
porsher
In my experience, Porsche steel welds very nicely.
I have cut and welded the engine carrier and engine tin, no probs.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Where did your part break? I just installed a new 60-2 missing aluminum crank pulley and had to use my plasma cutter to provide sufficient room for the A/C belt part of the pulley. I reinforced the area by your #1 above by welding in a 1/8" piece of steel.
Damon in STL
Damon in STL 1977 widebody with 3.0 1989 BMW M3 M42 1.8 Turbo Race Car |
that flange with the nut on it broke right off. so i need to reenforce and weld i think .
Oh...the flimsy little pieces. Just tack weld it back on. Use a small piece of sheet metal if necessary to support it. Cut it to size and bend it into an "L" and tack it into place. Paint.
Damon in STL
yup thats exactly what i was thinking .. damn flimsy bits get me every time.
Straight shooter
Rennline makes a very handsome piece in stainless iirc.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
