911 SC sound pad
Hello,
I have a 1981 SC and the sound pad has come apart. Does the engine have to be
pulled to replace?
thank you
Old 12-22-2014, 06:37 AM
It is possible (I have done it), but for sure it is easier without the engine. There are several good threads here on this. This one explains it pretty well.
Engine bay sound deadening
You will need to remove the air box and move some tubes (carefully). Another way is with a partial drop (6 inches or so).
Good luck.
Old 12-22-2014, 06:47 AM
TheSt|G's Avatar
Number of people have attached the new version with magnets. I'm pretty tempted to try that out.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 12-22-2014, 06:49 AM
KNS KNS is offline
I replaced the sound pad in my '80 SC by dropping the engine about three or four inches. It's doable.
Kurt
Old 12-22-2014, 07:25 AM
Any thoughts as to replacement pads?
Photos?
Wayne
Wayne
1980 911 SC
1960 MGA 1600
Old 12-22-2014, 07:54 AM
Have a new pad ready to install; the original had a thick "skin" that faced outward, the new factory one not nearly as thick. Either way, I assume that the skin should face outward? Thanks.
Old 12-22-2014, 08:07 AM
