patz's Avatar
Immediate popping of 25A fuse for the windows.
Any good diagnostic threads?
Don't tell me to search, did that.
Old 01-01-2015, 02:17 PM
Designer King
Paulporsche's Avatar
When this happened to me, some wires were touching behind the door panel, causing a short. I pulled the switch out and spotted the offending wires.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-01-2015, 03:28 PM
Reiver
Reiver's Avatar
wires are touching a ground or each other. Start at the switches (pretty tight cluster and easy for a problem) and then where they go thru door etc.
Could be the switch itself....try the opposite switch in its place.
De Oppresso Liber
Strength and Honor 5th Legion
Old 01-01-2015, 03:59 PM
Has to be a dead short. Could be the wires worn through making contact with each other (most likely) or it could be the switch.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 01-01-2015, 04:08 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Any work done prior to this symptom or was it all of a sudden?
Window shares the same circuit as the power seats. I my case my power seat motor was grounding out on the steel frame after some work on my seats. Insulated it and all is well now.
'85 Carrera Targa
PCA/POC
Old 01-01-2015, 07:03 PM
Elombard's Avatar
one of the Window switches failed, had exact same problem a month ago.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-01-2015, 08:00 PM
Jose_JGC's Avatar
I agree with all that there is a faulty window switch or there are wires in contact with each other or with ground. The cluster of wires is very tight where it connects to the switches, making it easy for unwanted contacts, I applied shrink tube to insulate the wire ends on mine to avoid a similar problem.
Here is a link with schematics that were usefull to me the last time I dealt with these switches: Power Window Switch schematic
Jose
Old 01-02-2015, 10:42 AM
patz's Avatar
Yes, replaced rubber squegees a month ago. Do I have to remove the door panels to get the switches out or do they pop out?
Old 01-02-2015, 03:44 PM
Jose_JGC's Avatar
The switches pop out, but I prefer to remove the door panels to gain working space and to avoid damaging the door panels. Once the door panels are out it is easy to push the switches out.
Old 01-05-2015, 04:47 AM
Discseven's Avatar
Had same problem. Cut ends of wires at window switches... placed new female spades... and heat shrink insulated up to spade. No more fuse replacing.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 01-05-2015, 05:40 AM
patz's Avatar
Ended up being an internal short on the passenger side switch. Put in another from "Brando's" garage queen. Tossed him some bucks, will buy another from our host.
I will use a FAF when I am dying of thirst
Old 01-17-2015, 02:17 PM
DRACO A5OG's Avatar
Congrats!
'85 Carrera Targa
PCA/POC
Old 01-17-2015, 09:15 PM
patz's Avatar
Was able to fix w/o removing the panels. Brando had a cool tool that popped the switch out.
Funny, now my radio has a clock function that I didn't know about. Gotta find the idiot book as it is three hours off and displaying a March 14th date.
Old 01-18-2015, 08:26 AM
To add my 1982 911SC window-fuse issue findings to an old thread (that helped me, thank you!) to hopefully help someone else in the future:
Issue: windows fuse immediately popped when ignition was turned on (no chance to roll any windows up/down). Tried replacing the fuse and, new fuse popped immediately. I suspected a short somewhere and started with the easiest approach: the switches.
I was able to pull the three door window switches (two drivers door and one passenger door) without pulling the door panel (pretty easy to do). I made notes of the wire colors/connections before disconnecting them to test.
But, before testing the switches, I took a close look at all of the wires I had just disconnected and found two wires on the passenger door had a tiny bit of bare metal showing just below the connectors (the wires had rubbed together apparently and were now shorting together). I was pretty sure I'd found my issue!
I taped the wires, reinstalled the switches (without pushing them back into the door yet), installed a new fuse and, success! I now have working windows again for $0!!! I cleaned up and went for a drive.
So, as somebody mentioned before, take a close look at the wires after you pull the switches. My short was very small but, it was enough to cause the issue.
82 911SC Wine Red
94 300ZXTT
Old 05-23-2017, 05:48 PM
