|  | LinkBack | Thread Tools | Rate Thread |
| Guest
					Posts: n/a
			Hi there,  I have a "new to me" 1980 911 SC Targa with the Ruf wide body.  Love the car!  But one thing bothers me...and it's the font wheels which are too sunk in.  I want to get spacers, there is 31mm gap between tire and fender.  What is the recommended gap?  I'm thinking a 21mm spacer would do the trick.  But then, do I need longer studs?  Current tire size is 205/50R16 see pic.  Any advice is greatly appreciated. Thanks. Roch.  __________________ This post was auto-generated based upon a question asked on our tech article page here: | ||
|  01-03-2015, 05:15 PM |
| Moderator Join Date: Jul 2012 Location: New England
			Don't know the answer to that one. I opened a post in our forums. A Pelican community member may be able to answer your question. - Nick | ||
| Member 911 Anonymous |
			Yes, you need longer studs. But before that make sure the new set up will not touch the very expensive RUF fenders. you may need to camber in to avoid damage after modification.
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  01-03-2015, 05:22 PM |
| Registered Join Date: Nov 2010
			Any side photos?  Maybe one directly from the front?
|  01-03-2015, 05:56 PM |
| Registered User |
			Here is a side view.  Are the studs easily removed and replaced with basic tools and knowledge?  Also, what lenght would I move to if I add a 21mm spacer?  thanks again. Roch.   | ||
|  01-05-2015, 05:35 AM |
| Registered Join Date: Jan 2006 Location: Clayton NC
			Why not use adapters?  Like spacers except that they have 5 holes for your present studs and 5 attached studs for the wheels.  A bit more expensive but you don't have the time and dollar expense of changing the studs.  They work fine and come in various widths.
				__________________ gary 70T coupe forever almost done 88 Carrera Targa diamond blue | ||
|  01-05-2015, 06:13 AM |
| Registered User Join Date: Oct 2012 Location: Austin Texas
			looks like the wheel offset is for a later car ....
				__________________ '77 911S Coupe 3.2 Turbo '76 911S Coupe 3.0 964 cams...no sunroof '75 911S Cabbie 3.2 SS Web cams & 46mm Webers '73 914 1.7 Webers & Header ... sold '74 VW 1303S 1600cc DP Web 110 & Solex | ||
|  01-05-2015, 06:15 AM |
| Registered User |
			#1 What he said   Wheel offset appears to be the problem here. Can we see a shot of the rear wheels as well? And the whole car. | ||
|  01-05-2015, 06:46 AM |
| Registered User Join Date: Dec 2012
			Based on my own recent experience, I'd be very cautious using adapters. I bought a set of 23MM adapters a few months ago from our host. They were very easy to install and I torqued each of the lug nuts to spec. After a few days of light driving I rechecked the torque and they weren't even hand tight. I've never had lug nuts back off like that before. Longer studs and hub centric spacers would appear to be a much safer route.
|  01-05-2015, 08:46 AM |
| Registered |
			Adapters (or bolted spacers) are fine to use.  They can be bought or custom made in almost any thickness, under 21 mm can be tricky. I use them a lot without problems, but they need to be torqued properly and you should always use a bit of anti seize on the shoulders of the nuts, otherwise you might not get the proper torque.
				__________________ Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. | ||
|  01-05-2015, 09:14 AM |
| Registered User |
			Here are some better pics.   | ||
|  01-06-2015, 05:46 PM |
| Registered User |   | ||
|  01-06-2015, 05:47 PM |
|  01-06-2015, 05:48 PM |
| Registered User |
			As you can see the rears are fine.  I just need to deal with the front.  How hard is it to replace the studs?  Is removing the hubs a DIY job with decent skill and tools?  Looks like the bolts just push out the back of the hubs.  Is that correct? the car is stored in my heated garage for the winter so I have time to do this myself if it's relatively simple. Thanks for all the input folks. Keep it coming! Roch. | ||
|  01-06-2015, 05:52 PM |
| Registered User |
			Use something like below and you don't need to change the studs. | ||
|  01-06-2015, 09:22 PM |
| Registered | Quote:
				__________________ '86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R | ||
|  01-06-2015, 09:44 PM |
| Registered |
Depends on the wheels. Most Porsche wheels has space on the backside between the  holes. But the link above shows spacers for a Porsche with lug bolts (Boxster/996...)
|  01-06-2015, 09:57 PM |
| Registered | Quote:
 Ideally you do it in a press, you can do it with a small sledge hammer on a bench so the hub can be supported, I wouldn't do it on the car (not the front). You have to hit it pretty hard...
				__________________ Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. Last edited by safe; 01-07-2015 at 12:38 AM.. | ||
|  01-06-2015, 10:02 PM |
| Registered User |
			Was a quick search, but yeah, those are technically for a Boxster. You could still use them however, you would just have some lug bolts as spares. I would go the bolt on spacer approach over changing studs personally. But both options achieve the same goal. | ||
|  01-06-2015, 10:59 PM |
| Registered User |
			Ok, so it looks like I have options.  Thanks gang.  I'm gonna do some shopping now. Roch | ||
|  01-07-2015, 02:48 PM |
