carrerarsr65
trailing arm bushings???
I have the engine out right now , is there a way to replace trailing arm bushings, with out taking apart the taking apart the whole arm assembly, in other words do the bushing while arm still attached. thanks al
Old 01-14-2015, 10:04 AM
Carerra, I had the same question in regards to my 82 SC. No, you must pull the arms. It isn't too bad. I bought "sport hardness rubber" bushings from Elephant. Having the use of a shop press makes the R&R of the bushings much easier. I did first try to get clever/cute and do this with the arms still in the car, but that was a waste of time and energy. John, Tolland CT.
Old 01-14-2015, 02:50 PM
I did mine. Taking out the arms is not bad. Scribe the position of the spring plates, leave the axles attached.
1986 3.2 to 3.4 conversion
Old 01-14-2015, 04:21 PM
Charles Freeborn's Avatar
Removing arms, especially with engine and trans out is a breeze. The inner ones (up near trans) seldom need replacing. Some cars came with the bolt heads facing inwards which required removing trans to get them out without cutting off the heads.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 01-14-2015, 04:36 PM
French Import
zippy_gg's Avatar
-C
Totally agree; I was very surprised that mine were still in very good condition.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-14-2015, 04:40 PM
