Guest
Posts: n/a
Hello, I'm doing this mod to a 2.4t cis. I will be installing a set of 86mm je 9.7:1 pistons to make int a 2.5 liters engine, with the 964 cams, the cuestion is the port size, the stock size is I 30, E 33 wich seems to small for this upgrade, I ask the advice of the engine and cis experts to advice me on this matter
Thanks __________________ This post was auto-generated based upon a question asked on our tech article page here: |
I am not familiar with this upgrade. Or at least not much of an expert. I will defer to the community.
I opened a post in our forums. A Pelican community member may be able to answer your question. - Nick |
PRO Motorsports
The 30mm port size is a little small.
But what you need to do is match your intake. If you are using the stock CIS intake from your '73.5, then the steel intake runners are tiny, and increasing intake port size won't make a difference. You should find a CIS intake from an '80-'83 911 SC and then make your intake ports match those. I believe they are 34mm intake ports, which would be just about right with the cam upgrade and displacement increase.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Bland
Why run 964 cams? I thought guys ran these because they were one of only a few options with stock CIS pistons because of interference.
Based on preamble on the 930 board, I think you could run a much better cam with CIS and the pistons you have selected provided you run anti reversion features (tapered spacers or smaller spacers than your cylinder ports.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Read Wayne's Engine Mod book about changing compression and cams with CIS....U may want to switch to carbs at a certain point....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Ports............
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Fleabit peanut monkey
The air (vacuum) pulsations with CIS flutter the smooth lifting of the air sensor and deliver fuel based on the up and down fluttering. Not good. That said, with higher compression pistons, OP needs to perform work to ascertain if pockets need to be milled.
1981 911SC Targa |
Banned but not out, yet..
Stupid question time (I have an endless supply). Can 964 cams be 'threaded' in without removing the head - just the cam covers? - No doubt an engine drop is in order. And what does a set go for approximately? Thx.
An air cooled refrigerator. ‘Mein Teil’ |
I have read that only the 2.7 S cams work if keeping the stock CIS. Anything else would need a different intake.
Ed 1973.5 T |
I converted my old 2.4CIS T to 2.7 liters with a set of factory Mahle 911S 2.7 (CIS) pistons and cylinders. I had to have the crankcase altered to take the larger cylinders, and I used Dilavar head studs. I left everything else - cams, heads, fuel injection and ignition - stock. It was a great autocross engine - lots of low range torque. It was not good at the top end, really running out of oomph before it would get to 6000 rpm. It was also a perfectly smooth running engine and a blast to drive on the street.
Just a data point for you to consider. |
