Engine Performance dyno results
Three liter motor w 10 3 to 1 compression running a mild race cam twin plugs and 48mm ITBs.
Not sure why it's not making more power? Please let me know if you can give me some help from the dyno numbers.
Old 02-06-2015, 06:39 PM
I've been told detonation might be taking place.
Old 02-06-2015, 06:40 PM
I would rather be driving
jpnovak's Avatar
What induction system? Did you get an AFR curve too? Not sure the mixture is set right with the roller coaster plot.
Do you have the data versus rpm?
Old 02-06-2015, 06:56 PM
48mm TMW throttle bodies
Old 02-06-2015, 07:08 PM
Will ask tuner for AFR curve on Monday.
Old 02-06-2015, 07:09 PM
jpnovak's Avatar
That's a lot of cam that requires a lot of rpm to take advantage of. What else did you do to the engine? Port sizes? What ECU?
Without rpm curves and AFR data its hard to say if the fall off at the end is due to tune or airflow or rpm or something else.
I assume you are looking for comments on the power level. I suspect that the engine should make more power than you see based on the type of cam and projected rpm level. I would expect upwards of 90hp/L which is a number higher than your peak.
You need to give a lot more details about the build to provide anything more useful.
Old 02-06-2015, 07:38 PM
Tech 3r.
Old 02-06-2015, 08:02 PM
Thought it would make power all the way up to 7100 rpms. Limited it to that because I didn't do better rods. I'm thinking it could be exhaust or cams are off a little.
Old 02-06-2015, 08:04 PM
Intake port was matched to 46mm manifolds which where ported to mate to 48 mm tmw throttle bodies. The manifolds are the tall ones.
Old 02-06-2015, 08:06 PM
Early 3 liter heads . Twin plugged
Old 02-06-2015, 08:08 PM
Will try and post pic of exhaust tomorrow. Was told that can make big difference.
Old 02-06-2015, 08:12 PM
Answered this thread on the Engine Rebuilding Forum.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-06-2015, 08:52 PM
Thanks Steve!l
Old 02-07-2015, 04:42 AM
evan9eleven's Avatar
Hey crash, just some friendly advice, this is a forum and not a chat program. Do us a favor and post what you need to say in a post or two, not a bunch of one-line posts in a row.
Cross-posting the same thing in multiple forums tends to be unpopular as well.
Just sayin'.
All that being said I enjoyed learning about your engine testing!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 02-07-2015, 12:23 PM
Timing and fuel maps might help too. I will tell you that dip in the middle looks suspect. Did you have someone do a professional tune?
Old 02-07-2015, 12:42 PM
It's a professional tune. I was warned the cam timing is off.
Old 02-07-2015, 03:11 PM
Those numbers are at the wheels?
Old 02-07-2015, 03:52 PM
Yes at wheels
Old 02-07-2015, 03:55 PM
