Senior Member
Superman's Avatar
Tire Selection Decision
I need tires and I would like to hear your suggestions. I want them to be grippy and quiet. It rains here in the pacific northwest, so certain tires will not work. Here are some pics to illustrate my preferences. In the first pic, the tread pattern is "V" shaped. My last set were like this, and I liked those tires (which are NLA). In the second pic is a typical "ultra performance all season" tire which, to me, looks like it belongs on a mini-van. Not my preference. In the third pic is an 'extreme' performance summer tire that would hydroplane like crazy on any wet road. Unacceptable. Recommend me an awesome tire with a tread pattern similar to the first pic.
Mocha 1978 911SC. "Coco"
Old 06-03-2018, 10:06 AM
Have you checked out the Conti DW? It does not have the V tread pattern that you reference but is a legit performance tire to handle the wet. I have their DWS on my daily (not 911) and love them.
Old 06-03-2018, 10:27 AM
Erbe_911's Avatar
I am also a huge fan of the Conti DW or DWS, I've run them on several daily drivers. I run Kumhos on the 911, for now at least, but will probably switch to Contis when the time comes.
Old 06-03-2018, 11:20 AM
Bridgestone RE-71R
Old 06-03-2018, 11:21 AM
looks like the bridgestone re-71 r tires have the tread pattern you want (but as "r" compound tires, will wear pretty quickly and don't seem to get the best reviews in the wet), but that the contis referenced above (and the michelin pilot a/s 3+ that I run/love) all have the "minivan" tread pattern that you don't like.
https://www.tirerack.com/tires/BigPic.jsp?tireMake=Continental&tireModel=ExtremeContact+DW&sidewall=Blackwall
https://www.tirerack.com/tires/BigPic.jsp?tireMake=Continental&tireModel=ExtremeContact+DWS&sidewall=Blackwall
https://www.tirerack.com/tires/BigPic.jsp?tireMake=Michelin&tireModel=Pilot+Sport+A%2FS+3%2B+%28W-+or+Y-Speed+Rated%29&sidewall=Blackwall
google "directional tire tread pattern" to see what's available in the style you like. That said, seems to me that you're really limiting yourself on tire selection by basing your choices on the appearance of something one won't really see unless they get down on the ground.
Old 06-03-2018, 11:53 AM
dlagerstrom's Avatar
I just picked up some of the Goodrich G-Force Comp Sport 2
So far so good.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
So far so good.
AND v-shaped directional tread pattern https://www.tirerack.com/tires/BigPic.jsp?tireMake=BFGoodrich&tireModel=g-Force+Sport+COMP-2&sidewall=Blackwall
Old 06-03-2018, 12:22 PM
What about the new Bridgestone Potenza S007A or
The somewhat new Continental Extreme Contact Sport ?
Would be interested if anyone has fitted this tire in stock sizes... 205/55 Front & 225/50 Rear.
Old 06-03-2018, 01:15 PM
Halm's Avatar
Just bought a set of the Firehawk Indy 500 for a new to me Boxster. They are a rebranded Bridgestone performance tire (RE-0003???) sold someplace else in the world. Go to Tire Rack and look at the reviews. They sold me.
'17 Cayenne
Old 06-03-2018, 01:45 PM
Functionista
manbridge 74's Avatar
Been working on a 79 SC with the Firehawk Indy 500. Drove nice while throwing it around a few turns. Brakes don’t lock up easy which is my clue to old or hard compound tires. It’s the goofy name that gets me....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-03-2018, 02:02 PM
S007a, Indy 500 and extreme contact sport all lack the tread pattern Superman indicates he’s seeking - rules out a lot of nice choices
Old 06-03-2018, 03:35 PM
toyo t1r have that pattern
Old 06-03-2018, 03:41 PM
Bill Verburg's Avatar
You cannot go by looks, that's just plain nuts
Tire rack sorts tires by use
here is their selection of Ultra high-Performance A/S tires.
do some reading, if you don't find anything to your taste use the menu on the left side for others
Bill Verburg
Old 06-03-2018, 03:47 PM
Senior Member
Superman's Avatar
I appreciate the input.
I had guessed that the V tread pattern is more high performance than the ribbed pattern. Perhaps I assumed incorrectly. I just want them to be sticky and predictable.
The S-04 has been around a LOOONG time. Good tire, I assume. RE-71 looks like a stickier tire with 'acceptable' wet performance. Hmmmmm....
Old 06-03-2018, 05:20 PM
TireRack - good advice, My choice would be Michelin Pilot Exalto PE2 first and Continental ExtremeContact Sport second.
Old 06-03-2018, 05:29 PM
RE71 is a marginal rain tire, absolutely wonderful dry
new tread depth is about what we used to get from shaved tires
Bill Verburg
Old 06-03-2018, 05:32 PM
Toyo T1R.
Old 06-03-2018, 06:01 PM
^^^ Toyo tires are the best..imo
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 06-03-2018, 07:38 PM
912 Geek
Goodyear's G-Force Comp Sport 2 is a great all-around tire: inexpensive, sticky on dry roads, good in the rain, even suitable for occasional autocross and track use. I've enjoyed several sets on a fast 912 and on strictly street-driven cars. Check Tire Rack for sizes and prices.
Old 06-03-2018, 09:07 PM
HarryD's Avatar
I am very happy with the Continental Extreme Contract Sport (formerly known as the DW) I just put on my 911. good grip in dry and wet and ok at Autocross as well.
I am also running the all season Continental DWS-06 on my Mercedes. also a great tire with some cold weather bones.
When the Bridgestone 760 Sports die on my Z-4, it will get a set of the Continental DWS-06's as well.
Can't say enough good things.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-03-2018, 10:12 PM
