Did any late '83 SC's get the 3.2 engine?
A friend of mine told me that my late (05/1983 build date) 911SC may have had the 1984 3.2 engine installed instead of the 3.0. He said to look for the round sump plate on the bottom of the cases as a way to identify the 3.0 engine. Mine does not have the round sump plate. I googled this but got no results...what's the verdict?
Old 02-21-2015, 03:16 PM
No, it didn't get a 3.2 engine. It may have the later case design, as that was introduced a little early.
JR
Old 02-21-2015, 03:24 PM
Registered knucklehead
83-911SC cab's Avatar
My 83 SC does not have the "round sump plate" you speak of....and it is the original 3.0 not a 3.2.. so don"t go by that as a determining factor of your motor size... look at the motor type # on the engine case.. it will be stamped in the case to the right of the fan housing and facing the rear of the vehicle... mine is a US 3.0 and is type # 930/16.
Gregg S.
Simon's Porsche 911 SC Site
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 02-21-2015, 03:29 PM
Reiver
Reiver's Avatar
Mid to late '83 production of the 3.0 liter SC 930-16 had the sump plate delete and same block as the 3.2.
De Oppresso Liber
Strength and Honor 5th Legion
Old 02-21-2015, 03:30 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Sump plate delete was to not allow peeps to drain their oil into the street? Oil had to be vacuumed out?
1981 911SC Targa
Old 02-21-2015, 04:44 PM
No. There was a drain plug, just in a different spot.
JR
Old 02-21-2015, 06:05 PM
Thanks for clarifying guys!
Old 02-21-2015, 06:16 PM
911SC Tinkerer
merlinfe's Avatar
Rumor was the original cast was worn out so they switched to the newer cast block for the 3.2. Ill find the ref when I'm at the house.
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 02-21-2015, 07:51 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
The case had to change to accommodate the Carrera oil pump pickup with the screen built in rather than being attached to the sump cover.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 02-24-2015, 05:06 AM
