Did any late '83 SC's get the 3.2 engine?
A friend of mine told me that my late (05/1983 build date) 911SC may have had the 1984 3.2 engine installed instead of the 3.0. He said to look for the round sump plate on the bottom of the cases as a way to identify the 3.0 engine. Mine does not have the round sump plate. I googled
![]() this but got no results...what's the verdict?
No, it didn't get a 3.2 engine. It may have the later case design, as that was introduced a little early.
JR |
Registered knucklehead
My 83 SC does not have the "round sump plate" you speak of....and it is the original 3.0 not a 3.2.. so don"t go by that as a determining factor of your motor size... look at the motor type # on the engine case.. it will be stamped in the case to the right of the fan housing and facing the rear of the vehicle... mine is a US 3.0 and is type # 930/16.
Gregg S. Simon's Porsche 911 SC Site
1983 911 SC Cabriolet, 1989 944 S2 1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455 2000 BMW 528i Touring, 2005 GMC Sierra |
Reiver
Mid to late '83 production of the 3.0 liter SC 930-16 had the sump plate delete and same block as the 3.2.
De Oppresso Liber Strength and Honor 5th Legion |
Fleabit peanut monkey
Sump plate delete was to not allow peeps to drain their oil into the street? Oil had to be vacuumed out?
1981 911SC Targa |
No. There was a drain plug, just in a different spot.
JR |
Thanks for clarifying guys!
911SC Tinkerer
Rumor was the original cast was worn out so they switched to the newer cast block for the 3.2. Ill find the ref when I'm at the house.
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Coram Deo
The case had to change to accommodate the Carrera oil pump pickup with the screen built in rather than being attached to the sump cover.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
