Mo money = mo parts
Sport Motor Mounts - Three Brands...Which One to Buy?
There are three brands of sport motor mounts . Rein @ $20, "German"@ $27, Hamburg Technic @ $24. I want to get the best quality, but highest price doesn't always translate to best quality and they are all close in price. Anyone have any thoughts?
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-13-2012, 08:06 PM
Go-Kart Mozart
JAR0023's Avatar
I just installed four of the $27 German ones. My research here showed a lot of folks saying to stick with Porsche mounts for longevity. I would have loved to go with a set from Wevo or Rebel Racing but it just wasn't in my budget right now.
Back to the mounts. Installed without issue. Night and day difference from the 26YO original mounts. Mine were bad. Lifting by engine would show an inch of movement in the rear. Hard on and off the throttle and and you could feel the trans mounts moving. Everything is nice and solid now. No offensive vibrations or noise. Long term, we'll see.
-J
Old 10-13-2012, 08:27 PM
kshafer1's Avatar
Just installed the "German" ones yesterday. They had the highest "pelican quality rating" (click the more info link for this rating) so I took their word for it. The price difference was not big enough for me to worry about it. I will say that the difference was noticeable when driving and I still need to do the two transmission mounts.
1979 911 SC Coupe
2000 VW Passat 1.8T
Old 10-13-2012, 08:39 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 on the German ones do all four while you are at it, just make sure the trans mount bolts go in straight. Take your time and be safe
'85 Carrera Targa
PCA/POC
Old 10-13-2012, 08:59 PM
Go-Kart Mozart
JAR0023's Avatar
True. One at a time. Be careful you don't break the engine carrier. I supported the engine with a floor jack for the rear mounts. For the trans mounts, once I had the car on jack stands I used a small bottle jack to support the nose of the trans. This was one of the easier jobs I've done. -J
Old 10-13-2012, 09:16 PM
I just bought two of the $27 mounts last week for my 71 911. I noticed that it has nuts at the bottom of the bolt. They are on super tight and there is very small room to even get a wrench in there. Any suggestions? I used some pb spray too.
Mh
Old 10-13-2012, 09:51 PM
DRACO A5OG's Avatar
Strange, can you post a pic?
'85 Carrera Targa
PCA/POC
Old 10-13-2012, 10:09 PM
DRACO A5OG's Avatar
If you are talking about the side bolts, raise the car and place jack stands at the T bar covers then lower the engine about 2 inches but not too much, just enough so after removing the center bolt, you should have enough room to get to those nuts with a wrench.
You do not want to lower the engine too much while the coupler is connected, it will damage your gear box shift rod.
'85 Carrera Targa
PCA/POC
Old 10-13-2012, 10:16 PM
Mo money = mo parts
Ok, thanks for the feedback. Obviously, this is an instance where there is a direct correlation between price and quality. I intend to get four of the german ones.
Greg
Old 10-14-2012, 05:09 AM
Grady Clay's Avatar
I’m not a proponent of having all four mounts being ‘stiff’ (or more rigid).
A 911 engine and transmission assembly is not designed to be a structural component of the chassis, it is designed to ‘float’ on the mounts.
With very rigid mounts, any ‘twist’ in the chassis structure is transferred to a ‘twist’ in the engine & transmission castings.
In turn, this can possibly misalign the machining (shaft bores) in the castings but will certainly stress the castings.
You can get the benefits of more precise location of the engine & transmission by using more rigid mounts at the transmission only while using good (new) Factory mounts at the engine.
A better design is a 3-point mounting system (like 914-6).
Just like a 3-leg stool, this design precludes ‘twist’ loading of the engine & transmission.
With a 3-point mounting system, you can even use (no-play) spherical bearings to locate the engine & transmission.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-14-2012, 05:13 AM
Undocumented User
McLaren-TAG's Avatar
I did just what you describe Grady. I used the hard inserts (replacement only) option on the transmission, and went with the softer black insert Wevos for the engine... eye candy there was hard to resist.
Old 10-14-2012, 09:28 AM
scotricker's Avatar
The pictures on the parts descriptions on the website all look the same. Are the parts all the same dimensions, but with different stiffness? Or are the trans mounts different from the engine mounts? I should order me some, too.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 10-14-2012, 10:05 AM
Go-Kart Mozart
JAR0023's Avatar
915 trans uses the same mount as the engine. G50 uses different trans mount. To answer your question cabriolet and sport mounts are stiffer than standard coupe mounts.
J
Old 10-14-2012, 11:00 AM
DRACO A5OG's Avatar
Dr Grady, is this why the Cabriolet has the extra engine strut along with all four Carbiolet Mounts (Sport Mounts) in pre-87's? Just curious.
'85 Carrera Targa
PCA/POC
Old 10-14-2012, 12:49 PM
ROW '78 911 Targa
timmy2's Avatar
I picked up the $20 ones (Hamburg Technic) for my Targa last year. Work great so far. Time will tell if they will last.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-14-2012, 01:38 PM
Vintage Motorsport
RichardNew's Avatar
That's what I did. The two solid ones at the transmission and the Porsche Sport ones in the back. It works just fine.
Richard Newton
Facebook
Old 10-14-2012, 02:09 PM
DRACO A5OG's Avatar
I may be wrong but I think Dr Grady is saying to use Sport/Cab mounts at the trans and OEM soft mounts at the engine.
'85 Carrera Targa
PCA/POC
Old 10-14-2012, 04:39 PM
tazzieman's Avatar
As per Grady , this 72 works RSR campaigning at the weekend's race meet doesn't weld the 330hp engine to the chassis. And the guy drove 300km home afterwards
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 10-14-2012, 06:18 PM
Weseeeee911
I just ordered 4 of the Sport Mounts. Looking at the records from the PO it appears that my mounts are almost 33 years old, 15 of those years I've owned it. Hope they smooth out the shifts a little.
Old 10-14-2012, 07:32 PM
Registered speed offender
78SCRSMAN's Avatar
I'm always entertained by the amount of pure bull$hit some people come up with when they really have no friggin clue what they are talking about and more importantly nothing to support their claim. Even more entertaining is watching the rest of the lambs follow the leader!
Go with the German ones, they're nice!
Please continue...
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 10-14-2012, 08:29 PM
