Item of unknown origin
All,
My first post on a soon to be started resto of a '73 911T. There is a metal container rolling around in the front boot of the car that is connected to a rubber hose on one end and looks like was originally connected to another rubber hose on the other end. It is oily and a mess now. it is a couple inches thick, rounded to a oval shape and maybe 8 inches long. Any ideas what this is? I could include photos if needed. |
Brew Master
A pic would help immensely.
could be an expansion tank for the fuel system..picture would help.
I'm guessing it's the charcoal canister for the fuel vapor recovery system. #3?
![]() I think the expansion tank is in the fender well, #2.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Yes, it is #3.
I assume it is important to the fuel system. Is its position vital or can it be moved to a spot, potentially higher in the fender? Also, can I use braided hose rather than rubber to plumb it? |
Fleabit peanut monkey
Go with braided.
I think Wayne has it here. Size will be the speed bump. I have never been able to figure out exactly what the parts diagrams meant when stating size. Here is a place that sells them. German Supply - Parts for VolkswagenŽ Cars - Breather / Vacuum Hose 4.0mm Red OE German - per Foot Here is a link to hose general info. Fuel Hoses
1981 911SC Targa |
If its rolling around, like mine was years ago, you will also need the rubber band/strap that keeps it in place.
72 911 Although it is done at the moment, it will never be finished. |
Thanks for the links and info. Mine is definitely rolling around, albeit in a sticky pool of oil at the moment.
