3.6 cis
Can anyone tell me about the major differences between 3.6 cis and 3.3 cis on the turbo's...regards jer
3.3 is CIS, 3.6 isn't (it's EFI).
Thank you for your time, |
I thought the early 90's 3.6 turbo used cis???regards jer
Schleprock
The 964 Turbo 3.3 and 3.6 are CIS motors.
The 993 Turbo is an EFI/DME motor.
Kevin L '86 Carrera "Larry" |
What? Is 964 3.6 turbo equipped with CIS??
You sure?
Irrationally exuberant
-Chris |
Is it the same unit cis on both?? anyone know the differences...ie. diff injectors ,metering....are they interchangable///thanks jer
Schleprock
Jer,
It appears that there is a lot of interchangeability on the two motors as far as the injection system is concerned. A large number of the parts are the same for the two different motors. A few things I notice are different. The M30.69 964 Turbo 3.3L motor and the M64.50 964 Turbo 3.6L motor use different injector valves, throttle body, and warm-up valve. Also looks like the Turbo 3.6 uses a vaccuum valve not used on the 3.3L. I'm just looking at a parts diagram, so take that for what it's worth.
Senior Member
So.....the esteemed "SC" model has the lengendary 3-liter turbo (930) engine, and also has a turbo fuel system, huh?
With hardware like that, those cars could rule the world!
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Schleprock
I'll have no part of this SCWDP craziness. I was just recently reprimanded by some newcomer for making tongue-in-cheek comments towards the SC faithful. I surely do not want to offend the newcomers again!!!!!
Thanks the information supplied is much appreciated....regards jer
