1989 3.2 Carrera-disabling brake pad sensor with race pads
Hi All,
I plan to install new performance brake pads on my 1989 3.2 Carrera. Since it seems some brands do not have slots for the pad wear sensors, do I need to disable my pad wear sensor system and, if so, how do I do that? Thanks, Jonathan |
You could do as others on here have done. And that is leaving it connected and use a cable tie to secure it
1984 Carrera 1985 Vanagon Westfalia 2009 Audi A3 2015 VW Jetta 2016 Sprinter |
Yep, just tie them out of the way.
Henri '87 Carrera coupe: Venetian blue |
Mine are zip tied. I believe the brake warning light will come on if you disconnect the sensor. Not positive about that though.
1989 911 Carrera Cab 25th Anniversary Edition Euro Pre-Muffler, SW Chip There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad" |
Member 911 Anonymous
+4, yes disconnecting the sensors will open the circuit and cause the light to come on.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thank you. I will tie them off with zip ties. After this NE winter, I cannot wait to get back on the road.
cycling has-been
sort of half-assed, but I cut my wires back to the firewalls then just connected the leads in a loop (one to the other) ...no more warning light.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
