How much cursing is involved removing window regulator
Any suggestions when removing and replacing window regulator
Old 03-19-2015, 07:44 AM
Significant cursing......
I replaced the window motor on my passenger side last summer. Had to completely loosen the regulator to get the motor off but left the regulator in the door the whole time. I remember thinking to myself..... "sure am glad I'm not replacing the regulator too!!".
It's really not rocket science and no worse than most other cars. Wear gloves unless you enjoy bloody knuckles. I want to say there is a certain position the window needs to be in to make it easier. You'll just need to play with it and pay attention to how it all mounts before you wrangle it out of there. I'd also remove the glass completely or at least tape it up in the closed position to keep out of the way.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 03-19-2015, 08:15 AM
TheSt|G's Avatar
I had no real issues with it. Just remember to secure the glass to the top of the window frame before you attempt to pull it. Also, nothing needs to be forced when removing it. If you are trying to do that your approach is wrong.
Nice opportunity to use some Wurth HHS-K on the mechanicals of the door while it is out.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 03-19-2015, 08:30 AM
Spiderman
Jesse16's Avatar
Window Regulator, 87
I just removed both of mine and got them back in finally, yes it is a pain. I took this short video of the orientation on my phone to remind me of the position of the parts as they came out. Helped a little but still a struggle.
http://youtu.be/GkdlJ9VoYAE
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 03-19-2015, 08:55 AM
I have a targa so there's no taping the window in the up position should I just remove it?
Old 03-19-2015, 10:40 AM
Uncertifiable!!!
Uwon's Avatar
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/756722-door-disassembly-how.html
Hope this helps.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-20-2015, 03:53 AM
walt's Avatar
I used a spring clamp on the glass to hold it in position. The regulator will pass thru the opening easily once you find the right position and path. Extreme patience required.
Walt
82SC 3.0
81SC 3.6
Old 03-20-2015, 03:58 AM
Brew Master
cabmandone's Avatar
I pinched my glass with a pair of quick grips with the protective rubber pads. I put one pair at an angle over the fixed vent window and the other I basically let rest on top of the door. It worked for me.
Old 03-20-2015, 10:19 AM
I don't have the answer; I don't even suspect. However, this is the second time this week I've run across a new phrase/word to add to my personal lexicon. The first was "buttholeryness", which I believe to be self-descriptive, and the second is "How much cursing is involved with . . .?" I'm going to use both.
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 03-20-2015, 03:54 PM
Thanks guys
Old 03-20-2015, 04:26 PM
