Fog light switch terminal ID
My 68 switch has terminals 1, 2, 3 and R as well as a bulb terminal. Which one is N, NR, and 58? My Kroon fog light harness is using a different switch in their instruction diagram.
Bob |
ROW '78 911 Targa
Show the end of the switch with all terminals visible. Can you detect any letters at the terminals?
Should be more than 3 terminals, which is all that is visible, and one is for the lamp. With a meter you can detect which terminal is which. Show a photo of the new harness as well.
Kroon Wire Harnesses
Foglight switch
Hi Bob,
Just send you an explanation by email. Regards, Gerard.
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
And here's a picture Dennis...
ROW '78 911 Targa
Do you have the original '68 style relay (rectangular) and wiring installed?
My guess is you may need to follow the '70 and later style switch wiring to work with the later fog light harness Gerald posted a photo of.
911 2.2E Sportomatic 1970
Hi Bob
Did you finally found an answer to your problem ? I have exactly the same problem |
