This has never been done by Porsche or anyone else for that matter with this new way THE gases always went to the rear first than the front UNTIL I DISCOVERED THIS FLAW AND REVERSAL OF THE GASES Believe it or not the hose length is about the same KINDA REMEMBER I AM NOT SPOON FEADING YOU REGARDING THIS |
Thanks for attempting to think out of the box despite the fact what you describe is merely changing the sequence of which condenser first receives heat-laden freon and not really reversing the refrigerant path through the system.
Imagine a true flow reversal where the high pressure side of the compressor (red) redirects to the evaporator but whose flow is restricted by the downstream expansion valve. A rupture in the former low pressure (blue), now high pressure line is inevitable. Uh uh. http://forums.pelicanparts.com/uploa...1427653939.jpg The system would work most efficiently if there were only one condenser (as pictured), but in the front and with a high capacity to transfer max. heat, enough to eliminate the need for an engine-mount condenser. It is this condenser that unnecessarily contributes to heat load. It is there only because it's in an available space with air flow. Sherwood |
No risk of that here given your pompousness. |
YOU and your Posts: 8,398 need a life outside these treads |
Whatever you do, don't cross the streams!
http://www.sherv.net/cm/emoticons/to...n-the-snow.gif |
It's OK guys.
It turns out it is reversal of condenser order. He wanted to present a riddle, so he said reversal of gases to add a little mystery. It's either a good idea or it's not. Reid claims it works well. I can see an advantage, but also more hose length. Anyone want to try it, then you can confirm or deny his layout superiority. Until then we'll just have to guess, or take Reid at his word. Dave |
Yeah, someone do this already and report back. :)
One day, gonna put AC in mine. |
You seem to be almost the only one here that thinks WITH THEIR BRAIN, Thanks for taking the time and effort to learn. You WILL DEFINITELY, SEE AN ADVANTAGE WHEN YOU TRY IT! Time will tell as you figure it out! I am not leading you on a path of BS, I would not do that to anyone! Instead of of all those opening their mouth to disrupt AND BS! IT FOR SURE WORKS, and even works better with my PFC's, but my PFC's work so well it won't hurt me to give it to the world as a Gift! I have a well known Porsche repair shop near me that LOVES THIS modification after I did it on one of this client 911's after which I did this on another one of his clients 911's that was even more complicated, and proved it to him and its a major selling point now for him and has has done several other 911 with very happy clients over this; he is not going to be too happy probably about me giving this to the world! But ITS MINE TO GIVE I discovered it on my own and proved it to myself in the middle of the night and I only gave it to him to use! GIVE THIS INFO TO ANY early model 911 owner that has OEM A/C and he will sincerely thank you the moment he try's this As this new 911 A/C GIFT from my heart spreads through out the world I know I will be remembered for doing something nice that affects others The Nay Sayers in this tread and on this topic for whatever reason have to be the stupidest people in the world when given a TRUE GIFT FOR FREE, THEIR stupidity is really fun to watch from my perspective LoL |
Tippy YOU NEED MORE THAN just THIS I think from what you told me in the past |
And to think you have the nerve to call other people "slow & stupid"! |
Okay, now I understand. I was not fully aware of the sequencing of condensers. Also, your terminology was a little too cryptic.
I think that the factory routing was an attempt to keep high-delta-T's; this generally results in greater heat transfer. The high temperature gas is cooled by the engine compartment condenser with medium air temperatures. Then the medium temperature gas is cooled by the front condenser with low temperature air. Theoretically this would result in lower final liquid gas temperature. However, when theory meets reality, then things can change. If the front condenser now does almost all of the cooling, then the rear condenser may even be a liability. I would carefully check inlet and outlet temperatures on the rear condenser to ensure it is still contributing to the cooling; it may not be, and in that case should be removed. |
First routing the HOT gas to the front lip condenser and then to the rear lid condenser leaves us with the EXACT same overall refrigerant condensing capability. Plus, isn't the total surface area for heat transfer a lot lower for the front lip condenser?
Net negative for A/C..?? My conclusion is that the only advantage is less heat load to/on the engine. It seems to me that making use of the cabin heat blower not only increases the efficiency of the rear lid condenser substantively, and only when/as needed, but is also as aid to cooling the engine via the extraction of heat from the exhaust manifold as is done with the 964/993 series. |
| All times are GMT -8. The time now is 02:19 PM. |
