-   -   A/C Reverse The Gases in Early Model 911's (http://forums.pelicanparts.com/porsche-911-technical-forum/858116-c-reverse-gases-early-model-911s.html)
wwest 03-29-2015 05:09 PM
Originally Posted by djpateman (Post 8552728)
Okay, now I understand. I was not fully aware of the sequencing of condensers. Also, your terminology was a little too cryptic.
I think that the factory routing was an attempt to keep high-delta-T's; this generally results in greater heat transfer.
The high temperature gas is cooled by the engine compartment condenser with medium air temperatures. Then the medium temperature gas is cooled by the front condenser with low temperature air. Theoretically this would result in lower final liquid gas temperature. However, when theory meets reality, then things can change. If the front condenser now does almost all of the cooling, then the rear condenser may even be a liability. I would carefully check inlet and outlet temperatures on the rear condenser to ensure it is still contributing to the cooling; it may not be, and in that case should be removed.
Are you supposing lower temperature airflow source for the front vs the rear...?
Or are taking the radiant heating effect on the rear condenser via the engine/exhaust into account?
It's hard to imagine that removing the rear lid condenser, ~2/3rds of the total condensing capacity, would net anything other than a negative result.
KelogGes 03-29-2015 05:16 PM
Originally Posted by Ronnie's.930 (Post 8552721)
That's a brilliant conclusion there, Reid! Did you not see the 2nd line in Tippy's post?
And to think you have the nerve to call other people "slow & stupid"!
SHUT UP you have no idea of my prior conversations with Tippy
I gave tippy good advice!
wwest 03-29-2015 05:24 PM
Given your public record that's hard for many of us to believe.
RSTarga 03-29-2015 05:25 PM
I wish someone was still making those underbody condensers, they work very well.
wwest 03-29-2015 05:29 PM
They may work well when "underway", but not very well at all for the periods our Porsche A/C most needs improvement.
Subject to road debris, radiant heat from a HOT roadbed.
Not in any way worthwhile.
KelogGes 03-29-2015 05:43 PM
Hi RSTarga
Are you talking about a belly-pan condenser?
Or something different?
As I custom make make condensers sometimes
I was interested in the belly-pan condenser and information about it
And had several conversations with 30 plus year expert Porsche shop owners and mechanics at length and informed none of them ever worked very well !
because there was no room for a/any blower, and they also picked up a lot of road heat radiation
Not to mention there was no room for a rock guard
Where does your information to say they work very well come from?
KelogGes 03-29-2015 05:51 PM
west why do you keep following me around you know what I think of you
Go take your meds there are enough crazy people drunk or on drugs in here already!
go disrupt a thead someplace else
Bob Kontak 03-29-2015 06:00 PM
SHUT UP
Woah. You need an attitude adjustment, Slick. A big time tune up.
I don't care f***-all about your invention. Calm your ass right down, you spoiled brat.
You like to s*** in people's nests. You will pay for that.
Keep it up.
Mark my words.
Bob Kontak 03-29-2015 06:03 PM
He's twice the man/person you or your kids will ever be.
KelogGes 03-30-2015 06:20 AM
Try it and you will discover what I say is true! What have you got to loose?
Regardless of what you might think of me for whatever reason the information I have posted here is true really important information and if reversing the gases is used on an early model 911 it is a game changer for making the a/c system make cold far better than the standard way regardless of the heat exchanger used and for over 35 years everyone has simply had the wrong mind set!
Reid Kelly
3/30/2015
Pazuzu 03-30-2015 07:20 AM
Originally Posted by KelogGes (Post 8552374)
roflmaO
I don't understand this.
You: "I discovered that running the hot gas to forward condensers first allows for cooler engine bay temps and better system temps. I discover this myself."
Me: "You discovered nothing because my setup (which is not factory, but is clearly the standard setup for this underbelly condenser) routes the hot gas to the forward condenser first, just as you claim you 'discovered', which means you didn't discover anything."
You :"roflmaO"
Makes no sense. Are you trying to say that I'm wrong about my car? That you really DID discover this, despite the fact that there is a standard installation that predates your discovery by about 10 years (when this was installed on my car)? Do you think that sending it to that tiny front condenser (while heating up the passenger compartment with hot lines back and forth, 20 feet of them) is better than sending it to the 2x4 foot massive passive condenser? I gotta say, despite your claims, this underbelly setup is pretty nice...
Pazuzu 03-30-2015 07:24 AM
3/30/2015
Um...several weekends and hundreds of dollars tearing out the old hoses and running brand new hoses back and forth, back and forth, probably 20-25 feet of EXTRA hose since you now make 2 complete circuits around the length of the car instead of just 1.
db_cooper 03-30-2015 07:42 AM
Yep..almost like an extra condenser in the high side plus extra refrigerant capacity..probably helps deliver more fluid refrigerant to the tiny 911 evaporator. Don't think it is worth the effort myself too. Will it work..sure..but is not "reversal of the gases"
Bob Kontak 03-30-2015 08:55 AM
I am not making a judgement on the tech end. Just lighten up.
KelogGes 03-30-2015 09:31 AM
1am early Sunday, ‎December ‎02, ‎2012 Reversing the Gases Proof This Invention Works
TEST 1am early Sunday, ‎December ‎02, ‎2012 Reversing the Early Model 911 Gases Proof This Invention Works
http://forums.pelicanparts.com/uploa...1427730743.jpg
http://forums.pelicanparts.com/uploa...1427730930.jpg
http://forums.pelicanparts.com/uploa...1427731463.jpg
http://forums.pelicanparts.com/uploa...1427731615.jpg
http://forums.pelicanparts.com/uploa...1427731826.jpg
http://forums.pelicanparts.com/uploa...1427732265.jpg
http://forums.pelicanparts.com/uploa...1427731964.jpg
KelogGes 03-30-2015 09:46 AM
This 911 I call THE BLACK SWAN GETS 37 F degrees average vent temps at @ 95 F degrees using my custom designed PFC's (without freezing)
The owner is extremely happy to say the least!
It uses only 0.95 lbs R134A refrigerant
This test was accomplished using a couple of pieces of hose fittings and hose clamps
All the existing hose was only disconnected and left in place until the next day so the shop owner could see how well the test worked
He liked MY INVENTION so well it was completed the next day using the new invention!
He has done several 911's since The Black Swan using my invention for his clients
wwest 03-30-2015 10:20 AM
Pictures swallowed by a black hole or just your way of remaining secretive?
911pcars 03-30-2015 10:35 AM
Originally Posted by KelogGes (Post 8553618)
This 911 I call THE BLACK SWAN GETS 37 F degrees average without freezing vent temps at @ 95 F degrees using my custom designed PFC's
It uses only 0.95 lbs R134A refridgerent
He liked it so well it was completed the next day using the new invention!
I must have missed it. What's the new invention?
Sherwood
billybek 03-30-2015 10:56 AM
This 911 I call THE BLACK SWAN GETS 37 F degrees average vent temps at @ 95 F degrees using my custom designed PFC's (without freezing)<br>
<br>
The owner is extremely happy to say the least!<br>
<br>
It uses only 0.95 lbs R134A refridgerent<br>
<br>
This test was accomplished using a couple of pieces of hose fittings and hose clamps<br>
<br>
All the existing hose was only disconnected and left in place until the next day so the shop owner could see how well the test worked<br>
<br>
There is no d in refrigerant.
aschen 03-30-2015 11:00 AM
Sherwood
he invented re-sequencing the condensers, even though it had been invented decades before
He also invented putting modern heat exchangers in a 911, even though people have been doing that for ever
I am beginning to think he doesn't no what innovation / invention means
He didn't even invent abrasive AC related posting, though he is quite talented at them
