-   -   A/C Reverse The Gases in Early Model 911's (http://forums.pelicanparts.com/porsche-911-technical-forum/858116-c-reverse-gases-early-model-911s.html)
wwest 03-29-2015 05:09 PM
Originally Posted by djpateman (Post 8552728)
Okay, now I understand. I was not fully aware of the sequencing of condensers. Also, your terminology was a little too cryptic.
I think that the factory routing was an attempt to keep high-delta-T's; this generally results in greater heat transfer.
The high temperature gas is cooled by the engine compartment condenser with medium air temperatures. Then the medium temperature gas is cooled by the front condenser with low temperature air. Theoretically this would result in lower final liquid gas temperature. However, when theory meets reality, then things can change. If the front condenser now does almost all of the cooling, then the rear condenser may even be a liability. I would carefully check inlet and outlet temperatures on the rear condenser to ensure it is still contributing to the cooling; it may not be, and in that case should be removed.
Are you supposing lower temperature airflow source for the front vs the rear...?
Or are taking the radiant heating effect on the rear condenser via the engine/exhaust into account?
It's hard to imagine that removing the rear lid condenser, ~2/3rds of the total condensing capacity, would net anything other than a negative result.
KelogGes 03-29-2015 05:16 PM
Originally Posted by Ronnie's.930 (Post 8552721)
That's a brilliant conclusion there, Reid! Did you not see the 2nd line in Tippy's post?
And to think you have the nerve to call other people "slow & stupid"!
SHUT UP you have no idea of my prior conversations with Tippy
I gave tippy good advice!
wwest 03-29-2015 05:24 PM
Given your public record that's hard for many of us to believe.
RSTarga 03-29-2015 05:25 PM
I wish someone was still making those underbody condensers, they work very well.
wwest 03-29-2015 05:29 PM
They may work well when "underway", but not very well at all for the periods our Porsche A/C most needs improvement.
Subject to road debris, radiant heat from a HOT roadbed.
Not in any way worthwhile.
KelogGes 03-29-2015 05:43 PM
Hi RSTarga
Are you talking about a belly-pan condenser?
Or something different?
As I custom make make condensers sometimes
I was interested in the belly-pan condenser and information about it
And had several conversations with 30 plus year expert Porsche shop owners and mechanics at length and informed none of them ever worked very well !
because there was no room for a/any blower, and they also picked up a lot of road heat radiation
Not to mention there was no room for a rock guard
Where does your information to say they work very well come from?
KelogGes 03-29-2015 05:51 PM
west why do you keep following me around you know what I think of you
Go take your meds there are enough crazy people drunk or on drugs in here already!
go disrupt a thead someplace else
Bob Kontak 03-29-2015 06:00 PM
SHUT UP
Woah. You need an attitude adjustment, Slick. A big time tune up.
I don't care f***-all about your invention. Calm your ass right down, you spoiled brat.
You like to s*** in people's nests. You will pay for that.
Keep it up.
Mark my words.
Bob Kontak 03-29-2015 06:03 PM
He's twice the man/person you or your kids will ever be.
KelogGes 03-30-2015 06:20 AM
Try it and you will discover what I say is true! What have you got to loose?
Regardless of what you might think of me for whatever reason the information I have posted here is true really important information and if reversing the gases is used on an early model 911 it is a game changer for making the a/c system make cold far better than the standard way regardless of the heat exchanger used and for over 35 years everyone has simply had the wrong mind set!
Reid Kelly
3/30/2015
Pazuzu 03-30-2015 07:20 AM
Originally Posted by KelogGes (Post 8552374)
roflmaO
I don't understand this.
You: "I discovered that running the hot gas to forward condensers first allows for cooler engine bay temps and better system temps. I discover this myself."
Me: "You discovered nothing because my setup (which is not factory, but is clearly the standard setup for this underbelly condenser) routes the hot gas to the forward condenser first, just as you claim you 'discovered', which means you didn't discover anything."
You :"roflmaO"
Makes no sense. Are you trying to say that I'm wrong about my car? That you really DID discover this, despite the fact that there is a standard installation that predates your discovery by about 10 years (when this was installed on my car)? Do you think that sending it to that tiny front condenser (while heating up the passenger compartment with hot lines back and forth, 20 feet of them) is better than sending it to the 2x4 foot massive passive condenser? I gotta say, despite your claims, this underbelly setup is pretty nice...
Pazuzu 03-30-2015 07:24 AM
3/30/2015
Um...several weekends and hundreds of dollars tearing out the old hoses and running brand new hoses back and forth, back and forth, probably 20-25 feet of EXTRA hose since you now make 2 complete circuits around the length of the car instead of just 1.
db_cooper 03-30-2015 07:42 AM
Yep..almost like an extra condenser in the high side plus extra refrigerant capacity..probably helps deliver more fluid refrigerant to the tiny 911 evaporator. Don't think it is worth the effort myself too. Will it work..sure..but is not "reversal of the gases"
Bob Kontak 03-30-2015 08:55 AM
I am not making a judgement on the tech end. Just lighten up.
KelogGes 03-30-2015 09:31 AM
1am early Sunday, ‎December ‎02, ‎2012 Reversing the Gases Proof This Invention Works
TEST 1am early Sunday, ‎December ‎02, ‎2012 Reversing the Early Model 911 Gases Proof This Invention Works
http://forums.pelicanparts.com/uploa...1427730743.jpg
http://forums.pelicanparts.com/uploa...1427730930.jpg
http://forums.pelicanparts.com/uploa...1427731463.jpg
http://forums.pelicanparts.com/uploa...1427731615.jpg
http://forums.pelicanparts.com/uploa...1427731826.jpg
http://forums.pelicanparts.com/uploa...1427732265.jpg
http://forums.pelicanparts.com/uploa...1427731964.jpg
KelogGes 03-30-2015 09:46 AM
This 911 I call THE BLACK SWAN GETS 37 F degrees average vent temps at @ 95 F degrees using my custom designed PFC's (without freezing)
The owner is extremely happy to say the least!
It uses only 0.95 lbs R134A refrigerant
This test was accomplished using a couple of pieces of hose fittings and hose clamps
All the existing hose was only disconnected and left in place until the next day so the shop owner could see how well the test worked
He liked MY INVENTION so well it was completed the next day using the new invention!
He has done several 911's since The Black Swan using my invention for his clients
wwest 03-30-2015 10:20 AM
Pictures swallowed by a black hole or just your way of remaining secretive?
911pcars 03-30-2015 10:35 AM
Originally Posted by KelogGes (Post 8553618)
This 911 I call THE BLACK SWAN GETS 37 F degrees average without freezing vent temps at @ 95 F degrees using my custom designed PFC's
It uses only 0.95 lbs R134A refridgerent
He liked it so well it was completed the next day using the new invention!
I must have missed it. What's the new invention?
Sherwood
billybek 03-30-2015 10:56 AM
This 911 I call THE BLACK SWAN GETS 37 F degrees average vent temps at @ 95 F degrees using my custom designed PFC's (without freezing)<br>
<br>
The owner is extremely happy to say the least!<br>
<br>
It uses only 0.95 lbs R134A refridgerent<br>
<br>
This test was accomplished using a couple of pieces of hose fittings and hose clamps<br>
<br>
All the existing hose was only disconnected and left in place until the next day so the shop owner could see how well the test worked<br>
<br>
There is no d in refrigerant.
aschen 03-30-2015 11:00 AM
Sherwood
he invented re-sequencing the condensers, even though it had been invented decades before
He also invented putting modern heat exchangers in a 911, even though people have been doing that for ever
I am beginning to think he doesn't no what innovation / invention means
He didn't even invent abrasive AC related posting, though he is quite talented at them
Ronnie's.930 03-30-2015 11:12 AM
Since we're showing braggart pictures that have been posted umpteen times before in other threads . . . 98 ambient, serpentine evaporator and fender condenser, OEM Turbo tail and nose condensers (tube and fin), conventional condenser/refrigerant routing, r134a, heavily insulated evaporator box, GM blower motor set on highest speed setting, no freeze up, results repeated over and over in all imaginable driving conditions (stop & go, highway cruising, parking lot heat soak, etc.) - getcha suuummmmm!
http://forums.pelicanparts.com/uploa...1427738974.jpg
KelogGes 03-30-2015 02:12 PM
roflmao
NO obsolete junk here and no 3 heavy condensers like you have with even more heavy a/c hose
and my posted temp was on a 911 on the lift not moving at idle
Ronnie What does this have to do with reversing the gases and giving the info away for free?
911pcars 03-30-2015 04:05 PM
For A/C aficionados, especially those enamored with R12 refrigerant. Do an internet search and read about the latest A/C improvements and components.
No. I didn't invent that, just did a search and noticed some thoughts on evap and condenser design.
Sherwood
KelogGes 03-30-2015 05:58 PM
George I just saw a pic of your car here, you have a nice looking
87 911 coupe, GP white, cashmere /black
Coastr 03-30-2015 09:02 PM
Why not just post like a normal person? What is it about AC threads that causes odd behaviour?
Quite a strange phenomena, when you think about it.
Ronnie's.930 03-30-2015 09:52 PM
Originally Posted by KelogGes (Post 8554073)
roflmao
That temp was measured at idle in my garage with a barrel fan running in front of the car and pointing rearward (to keep heat from building up under the engine).
Reid, you disparage all other forms of a/c upgrades (labeling such as, "crap, junk, garbage, obsolete" and so forth), degrade those who sell and install/use them, and claim that you have created vastly superior alternatives that trump all others; my post above both refutes your pompous, condescending boasts (that temp reading at 98 ambient was with suction pressure of 30psi and discharge pressure of 210 psi, by the way) and "gives away" very useful information for free (information that other people are free to use to get nad shrinking a/c performance, and which I do not arrogantly claim to have discovered) .
You might have a good a/c idea or two, but when you come here beating your chest, making false claims of superiority, and unabashedly slamming all other proven a/c modifications, then you deserve to be called to the carpet each and every time.
911pcars 03-31-2015 01:29 AM
KelogGes, I re-read the beginning of this thread and your tone was quite normal (2011). However, in the last few pages, overexhuberance and hyperbole seemed to put off forum inhabitants.
It sounds like your custom-fit, micro channel, parallel-flow condenser should improve A/C efficiency. However, re-routing the refrigerant path requires more hose, rigid or otherwise. Your suggested path; rear comp.>frt cond>rear cond>frt. rec-drier>exp valve>evap>rear comp. = 4 lengths of refrig. line). Perhaps there's one super-efficient, front-mount condenser with fan support can do the job like most other vehicles.
And I would lose the "reverse gas flow" claim and instead use another phrase to describe the revised gas flow path, like, "modified flow path".
Sherwood
KelogGes 03-31-2015 06:22 AM
uuse your brain and think about reverting the gases
Originally Posted by DaveMcKenz (Post 8552351)
No extra hose?
It seems the hose will go from compressor to front condenser, then back to rear deck condenser, the forward again to receiver/drier, then evaporator.
That is pretty much one extra trip front and back to pick up rear condenser. I'm not sure that's really a problem, but it does mean extra hose, unless I am missing something. (Which is very possible.)
Dave
Dave is starting to get this this using his brain
use your brain and think about reversing the gases
this is not about necessarily using my PFC''s
the pictures I posted are proof this works far better than the traditional way
figure it out in your brain
Doing this makes an incredible difference for several reasons
techman1 03-31-2015 09:00 AM
Not sure why you are stuck on the "reversing the gasses" statement.
Maybe you need a story to help you grasp our misunderstanding.
Tommy the truck left the station, headed to Walmart. As he was pulling out onto the highway, dispatch radioed and re-routed him to K-Mart first. Dispatch did not say "reverse your course", else Tommy would have stopped, and backed back into the station. He was re-routed, not reversed, which implies the direction of motion has changed. In your theory, the motion is still the same, the route has changed.
Regardless of how great an idea is, if the communication does not happen, the idea is not shared.
wwest 03-31-2015 09:53 AM
KeloGes' statement:
"words of wisdom and experience
Extra Rear Deck Fans are never needed
YOU HAVE A HUGE 911 ENGINE FAN that will pull the balls off a goat
Seal your rear deck lid condenser so it is COMPLETELY sealed to the rear deck lid and let the engine do the work with its fan!
toss the useless fans you added, or give them to wwest to sell to some unsuspecting numskull LoL"
wwest's statement:
"Do the numbers....
Front condenser, 22X6" 132 sq. inch. Average airflow, 110 FPM.
Factory condenser, blower. 60 airflow measurements, 3 measurements each inch across.
Rear condenser, 800 RPM engine idle, 27.5X8.5" 233 sq. inch. Average airflow 150 FPM.
Anomaly: No measureable airflow for the first 10" of front condenser from battery side, peak measurement was 430 FPM at 11"
Conclusion: rear condenser is 240% more effective at heat transfer vs the front lip condenser.
"Boosted" rear condenser airflow using the cabin heat blower = 186 FPM.
Cabin heat blower airflow inlet is open to atmosphere and sleeved for increased "work"."
KeloGes is correct, the engine cooling fan will pull the balls off of a goat.
With the engine RPM at or above 2500 RPM.
FACT: The factory stock rear lid condenser is 240% more effective at cooling the refrigerant vs the front lip condenser.
From the numbers it is quite clear that rerouting the refrigerant flow to the front lip condenser first would yeild no A/C performance gain whatsoever.
So KeloGes's brilliant idea turns out to be nothing more than a SHAM, putup!
It's pretty clear that the least expensive & complex method, most elegant method, for improving the performance of our A/C is to add cooling airflow through the rear lid condenser, be it Spal fans or simply engaging the cabin heat blower. The latter can be done selectively in the '84-88 models, or direct connection to a trinary switch. In worse case switched on with the A/C as with the front lip blower.
Switching fans on with compressor clutch power is not the best of ideas since the high pressure remains for quite some time post compressor shut down.
KelogGes 03-31-2015 10:05 AM
think using logic or get someone to help you this is not rocket scientist stuff
draw out a diagram and figure it out
re-diagram the early model 911 a/c in your mind or on paper reversing the gases and its obvious
look at the pictures and clues I posted
I am not going to spoon feed anyone because your lazy
:D
KelogGes 03-31-2015 10:21 AM
This has nothing whatsoever to do with the topic of this tread
[QUOTE=wwest;8555335]
Originally Posted by KelogGes (Post 8554439)
DaveMcKenz
KeloGes' statement:
wwest's statement:
"Do the numbers....
FACT: The factory stock rear lid condenser is 230% more effective at cooling the refrigerant vs the front lip condenser.
This MIS QUOTED BUNCH OF WORDS FROM BY WWEST FROM SEVERAL OTHER POSTS AND OUT OF CONTEXT has ABSOLUTELY NOTHING whatsoever to do with the topic of this tread
wwest 03-31-2015 10:22 AM
:D
Speaking of LAZY, why only clues and NOT ACTUAL FACTS???
The pictures and clues you have provided so far only indicate that rerouting works, not necessarily better and maybe WORSE.
Your reroute results in making, having, the front lip condenser do more work, but is there really a net advantage.
My measurements indicate NOT!
In a control environment how long to bring the evaporator to a specific temperature from ambient with the engine at idle, max A/C blower, doors and wiindows open, in each configuration.
wwest 03-31-2015 10:31 AM
[QUOTE=KelogGes;8555381]
Originally Posted by wwest (Post 8555335)
This MIS QUOTED BUNCH OF WORDS FROM BY WWEST FROM SEVERAL OTHER POSTS has ABSOLUTELY NOTHING whatsoever to do with the topic of this tread
If you would be so kind as to point out any mis-quoting I have done I will quickly correct same.
GH85Carrera 03-31-2015 11:13 AM
This is like A/C comedy gold. Those two arguing about AC.
It is much like the old Saturday Night Live skit were a bunch of men sat around and discussed "Women's Problems"
Next up a 12 year old boy singing the Frank Sinatra classic "My Way"
Pure comedy.
Bob Kontak 03-31-2015 11:33 AM
Originally Posted by KelogGes (Post 8554982)
Dave is starting to get this ... using his brain
Dave is no slouch.
I am subscribed to the tech content. Even the riddle mystery.
Bob Kontak 03-31-2015 11:34 AM
Heh heh.
911pcars 03-31-2015 11:57 AM
Maybe the powers to be can split this discussion into separate threads. The original post has sequed into other territories. One thread can go to OT. :)
NYNick 03-31-2015 12:30 PM
This guy is a fricking idiot.
Mark at Pelican Parts 03-31-2015 01:49 PM
This thread is deteriorating as well. The tone here isn't great is it. Here's a chance to turn it around.
