Dave |
Sherwood,
I don't disagree with you but here's the issue. The expansion valve opens based on the sensing tube to allow a pressure differential across the valve. When this happen the higher pressure pushes the liquid through the expansion valve and gas or vapor is emitted from the other side. Now if the pressure isn't high enough based on the design of the expansion valve then there is a possibility that liquid could be emitted instead of gas. As a result you will have what's called "evaporative flooding resulting in the evaporator temperature to drop below freezing. The expansion valve will modulate but in doing so it will cause the refrigerant to surge causing an unstable condition. In other words lets say there is gas going across the evaporator and the sensing bulb senses this. As the temperature drops in the coil the sensing bulb starts to close the expansion vale thus reducing the flow of refrigerant. However it doesn't happen immediately - so what is going to happen is the refrigerant will keep flowing and the evaporator has the potential to be flooded with refrigerant. The expansion valve is not designed to avoid evaporator freezing. That is the main reason the temperature sensing switch is designed to a cutoff/cut on range of 40 - 45. That is why I am asking the question about how KeloGes is controlling this. It's great to get a 30F temp as was shown but that tells me the evaporator is being flooded. |
The Black Swan was ORIGINALLY only a minimal A/C Project, the owner only wanted new PFC's and New hoses. But I decided to try something crazy never done before to the best of my knowledge; that had been in in the back of my mind for a long time; for me turned into costing me money due to the amount of time I spent on it (an extra OVER a week of free labor due to the discovery and changes made that had nothing to do with just making him PFC's But it had other benefits for knowledge learned, from not just the gases discovery but also the Minimal alteration and modification needed to make an early model 911 get constant 30 degree F vent temps @ 95 degrees Ambient I have moved on to several other related 911 A/C engineering design things i.e. THE TAN SWAN with a completely new full set of components Everything Redesigned to new technology finished Last but not least, latest; DIGITAL MICRO PROCESSOR CONTROL As I said, THIS REALLY WORKS! I don't need reversing the gases and keeping this 3 year old proven secret, and am giving it to all early model 911 owners as a gift for free from my heart! TEST IT AND PROVE IT TO YOUR SELF OR DON'T; THIS IS A FREE GIFT THAT IS NOT BS! |
And dump your TX valves in the trash and start using "VOV Orifice Valves" together with a small EXPANSION TANK LOOK up "SMART VOV Orifice Valve" and start reading and learning! FYI, Police Departments in the hot desert in Nevada, New Mexico, Arizona swear by them Don't forget to also look up "Orifice Valve EXPANSION TANK" |
That is NOT the problem we have. At idle, 800 RPM, the compressor is more than adequate at pumping refrigerant. :rolleyes:Provided one doesn't follow the wrong guidelines and undercharge the system in order to get sub-freezing evaporator temps. Our problem is, and always has been, the lack of adequate condensing capability to keep the high side pressure low enough to feed the R/D with LIQUID refrigerant. |
You guys know, the old school test of condenser adequacy is to spray cold water over the condenser, and see if the vent temps go down. I truly believe that condenser capacity is the limiting factor in our cars and most a/c systems. Increased air flow or increased condenser capacity will address those problems. The fact that r\Reid mentions it in his post suggest that his system is at threshold for condenser capacity. That means that anything that improves it by any means will be beneficial.
Good luck, Dave |
May the force be in reverse flow. Sherwood |
I understand, Sherwood. Reid is abrasive. I have worked with guys who were abrasive, but their ideas justified the effort. He doesn't care about being sensitive. He has told me I have finally started using my brain. You have no idea how much I have used my brain and continue to do so, but I accept his statements as a compliment as far as he can handle them.
I will always give an experimentalist a lot of respect, just as I was given the same in my former life. Unfortunately he was not gifted with the interpersonal skills to match his purported intellect. Let's give him some slack and see what he has to say when nobody is picking on him. Thanks, Dave |
Thank YOU Dave, you are a true gentleman!
I also like the fact in the way you're trying to learn new technology send me your number by priv message and I will call you if you like and answer any question you have I can answer I don't think it is worth my time sharing anything anymore with the ones here I don't like that have dogged me for-years for anything and everything I say regardless of the subject My sincerest apologies to those in the background who don't post in the treads and seeking knowledge that are courteous and respectful, this place is a zoo with tooo many adult children that run ramped in packs IN THE A/C RELATED THREADS, take a look it goes back for years with ruined a/c threads and you will see what I mean |
BTW, Reid, the "dogging" you get is well earned and you know it - you loudly claim a/c superiority in theory, design and execution, malign existing a/c products and practices, as well as those who offer and use said products and practices, and have NEVER shown a shred of evidence that supports your chest beating. You have been doing this for years. What exactly do you expect? Do you think you should be praised for lobbing bombs in the name of self-proclaimed superiority while offering as evidence results that are, in fact, inferior (or at best, maybe equal) to what you say is garbage/obsolete/junk/rip-off ideas and products? And if not "praised" do you think your unsubstantiated boasts and mud slinging should simply be allowed to be presented (over and over) without retort? |
It was a wise discussion i made but you don't deal well with rejection and have been bashing me ever since! Now all you do is lie about me and spread bs about me because i rejected you |
Shock to the System
<iframe width="640" height="360" src="https://www.youtube.com/embed/_icf-5uoZbc?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
Holding Back The Years
<iframe width="640" height="360" src="https://www.youtube.com/embed/yG07WSu7Q9w?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
Holding Back the Years......... Loved that tune. |
And Bob, did you notice the nuggie that Will gave me? I guess Hell froze last night (probably a refrigerant undercharge)! :D |
Thermal Expansion valves (TXV) have been made for probably a 100 years now The ones made in the USA and Europe are made well IF THEY ARE THE HIGH QUALITY ONES The China ones really suck ONLY THE High Quality TXV's kinda work OK but even these TXV's do not meter gases precisely at all I always adjust them and manually set THE TXV SUPER HEAT on 911's to inject more liquid refrigerant into the evaporator down in the LOW 30s; but ALL TXV's DRIFT UNCONTROLLABLY, they can not be precisely set to meter; they constantly put out too much or too little refrigerant and "ARE NOT A PRECISE METERING DEVICE"! Orifice Valves ON the other hand can be VERY PRECISE METERING DEVICE |
I offered to "Texas-test" your micro channel condensers that you were claiming were the a/c gods' (aka: you) gift to 911 air conditioning and you declined due to your fears of having the rug pulled out from under you. Ohhhhh, such heart rending rejection! |
2015 can be a good year for AC threads. I can only say what Willy and I have said from the beginning......... <iframe width="420" height="315" src="https://www.youtube.com/embed/FfBwsG8ubFw" frameborder="0" allowfullscreen></iframe> |
I think I have cut a few in half when replacing a line or two on some mid 2000's Fords near the R/D. |
Look what I just found. What's going on anyway - I would have though by now that KelloGes would have already had this on the market.
This thread starts in 2011 - Seems to me something is wrong when the thread gets shut down and another one is started up. What gives. http://forums.pelicanparts.com/porsche-911-technical-forum/617196-i-make-parallel-flow-micro-channel-condensers-911s-front-rear.html |
^^^ Bob, aren't you and orifice expert?!?!
We can eff around in other threads. Deal with it or take my wrath. You wanna cha-cha? I will cut you. |
I hope you sing Don't Rock the Boat all day in your brain tomorrow. |
You sucking down yellow marshmallow eggs? Better yet, those orange foam circus peanuts. Cat got your tongue, Willis? |
I'll share the level quality and fit of the product... ;) |
Your not the kind of person I want to do business with after checking you out! |
<iframe width="640" height="390" src="https://www.youtube.com/embed/SRwrg0db_zY" frameborder="0" allowfullscreen></iframe> |
making progress for you |
I know Ronnie and consider him a real friend that I trust. I will align with him in a heartbeat. There is a big difference between harboring spite and *****-slapping someone for cranking out 90mph wind. He is a fair man and has sound judgement. However, his ability to temper his thoughts (before typing) are about as good as yours or mine. I call misdemeanor vs. felony. Let it go. |
^^^ Bob, your check is in the mail - $2.00 just as we agreed upon! :D
PORSCHE STOCK OEM EARLY MODEL 911 A/C SYSTEM FRONT AND REAR TOTAL OF 2 CONDENSERS A/C SYSTEM
TUBE AND FIN TECHNOLOGY http://forums.pelicanparts.com/uploa...1428290287.gif PORSCHE ENGINEERING MAJOR DESIGN FLAWS THEY REALLY SCREWED UP! AND ITS STILL THE SAME STUPID MINDSET TODAY |
Reverse the gases!!!!
I am giving you a gift Figure IT OUT TEST IT AND YOU WILL SEE MY DISCOVERY WORKS |
I got tens and tens of dollars. |
to each their own but I am into new technology
http://forums.pelicanparts.com/uploa...1428293852.jpg
http://forums.pelicanparts.com/uploa...1428293701.jpg OBSOLETE 20 YEAR OLD OR MORE A/C TECHNOLOGY AND THINKING 3 VERY HEAVY CONDENSERS AND HEAVY HOSE ONE IN THE WHEEL WELL AND ALTERING THE BODY AND ADDING EXTRA WEIGHT PICKING UP HEAT FROM THE ENGINE EXHAUST NOT A GOOD IDEA Why anyone would use obsolete serpentine technology and/or tubes and fin technology today is beyond me??? But to each their own mentality. My engineering designs only use 2 very light weight custom made aluminum state of the art 'PFC's that only weigh a few lbs each AND FIT LIKE A GLOVE in an early model 911 original OEM front and rear condenser mounting spaces, and when properly installed get vent temps in the 30's @ 95 F degrees |
I figured it out, KeloGes doesn't believe this crap he's spouting any more than we do. If he did the men in white coats would have locked him up long ago.
So, just to get a "rise"..??? |
Exactly! Reid is doing the very thing he so often accuses others of; "trolling the a/c threads". |
| All times are GMT -8. The time now is 12:02 PM. |
