Still waiting for someone to post data other than vent temps..... personally I would like to see what are the temps at the entrance and exit of both condensers, at least, for both forward and reverse flow situations. First is to benchmark the std arrangement, in order to get an idea of how much heat is getting removed from the rear cond and possibly added to the engine, very roughly, not going thru the Qdot calculations .
Then with the reverse flow setup someone could provide those temp numbers. In this case, the rear cond. should be cooler by the amount of heat removed by the front cond. So how much cooler air is the engine getting? 5 degrees or 40 degrees change ???? Will it make a difference in oil temps? We have heard all the talk and theories, the data will show. Well I was not going to get involved but ,...show the data. |
Not to mention an integrated DATA LOGGER Good Luck getting this from a DIY'er DIY'ers are not laboratory testing facilities, so you're asking A LOT |
George Why go through all that ;; simply hook up some temporary hoses after "you already know your current a/c vent temps with out this installed at a certain @ ambient temperature" After temporarily hooking up reverse the gases test it @ the same ambient temperature and take your vent temp temperature "with A THERMOMETER" "THAT WILL ACTUALLY MEASURE AIR TEMPERATURE"
ANALOG OR DIGITAL, I like digital meat/cooking thermometers the best because they are very fast readings of changing temperatures, and you can find them in most grocery stores NOT an IR or Laser pointing IR gun!! An infrared thermometer is a thermometer which infers temperature from a portion of the thermal radiation sometimes called blackbody radiation emitted by the object being measured. IT CAN NOT SENSE OR MEASURE AIR TEMPERATURE! An infrared thermometer is a thermometer which "infers temperature from a portion of the thermal radiation sometimes called blackbody radiation emitted by the object being measured" BUT NOT FROM AIR! You can use an IR gun for surface's temperatures, but again NOT ACTUAL AIR TEMPERATURE, A/C STANDS FOR "AIR CONDITIONER" NOT SURFACE TEMPERATURE! BUT if you must go ahead and do it the hard way <grin> the in out condenserS temps and the way you are wording what you are requesting will give you a skewed test result I am trying to help you the easiest way I forgot to say you can use an IR gun on the fittings on the condenser or the condenser itself because it is NOT AIR, it is surface temperature |
Well, I use to have an Omega 32 channel data aq, that would be an interesting characterization.
You do it , right up your alley. |
But I will come by to view your test if you like I am completely bias because not only invented this I have installed Reversing The Gases Three times fully tested it and absolutely know it works, and have no interested in testing this again, it WORKS GREAT! My interest is in state of the art PFC technology new designs and development that are even more efficient and/or PRECISE digital micro processor temperature control of of evaporators @ 32-33 degrees F Or you CAN wait until the west coast 86 SC Carrera Cabriolet DIY owner posts his numbers and description after he installs the PFC's etc, I am sending him and let him test it for DIY early model 911 community I have given my invention too. The west coast Cabriolet DIY owner is my priority helping him be successful making his 911 ICECOLD |
http://media.giphy.com/media/E34abL6pC9IOY/giphy.gif |
Bakersfield, Ca, maybe ??? |
Reid, since you obviously missed it the first time, it would behoove you to read Eric's words of wisdom on IR thermometers, and then perhaps, you will stop spreading misinformation about them and their usefulness in a/c applications. Quote:
This could get nasty. |
http://i.ytimg.com/vi/QPmZ9RR887U/hqdefault.jpg |
Nasty good!!! http://prontv.org/uploads/posts/2013..._jada-fire.jpg |
Doesn't she need some kind of permit to be packing that much game? |
Willy could pull 15 with the steel rod implant that you have to be 80 to receive, by law. |
https://encrypted-tbn0.gstatic.com/i...aOH41-m-9bULMl |
Hey Ronnieeeeeee
You know how Willie says we are married? How about if he keeps it up we spill the beans about his Mrs at our consummation party and the noise she can crank out when she is being handled properly. |
| All times are GMT -8. The time now is 01:42 AM. |
