IMO only with a mighty slow, virtually stopped, evaporator blower speed. 65dF single pass temperature differential....??? One mighty good A/C...!! And do we really want to trust that KelogGes abides by those conditions? |
ICECOLD911s
Sez the Mighty Pieholio!!! http://www.visualphotos.com/photo/2x...wberry-pie.jpg |
the BS is you
REVERSING THE GASES IN THE EARLY MODEL 911 A/C SYSTEM THE A/C TEMPERATURE IS MUCH COLDER!
ALSO THE ENGINE OIL TEMPERATURE DOES NOT appreciably RISE WHEN THE A/C IS TURNED ON LIKE IT NORMALLY DOES! TRY IT YOU WILL LIKE IT |
Somebody with a IR thermometer get readings at the inlet and outlet of front and rear condensers.
Porsche's engineers made a simple mistake I have discovered that continues to this day and fixed it by thinking outside the box I have tested my discovery and installed it on 2 different early model 911's that are using my PFC's and proven it works; and its being installed on other early model 911's in south Florida by a well known Porsche repair Shop I am bring this discovery forth and giving it to the world's early model Porsche's owners for free |
Then wouldn't be to their benefit to post their information..?? If I owned such a shop I would LOVE the positive exposure... NOTHING beats FREE advertising. You can't post your logical concept because it works but you don't understand why..?? |
an IR thermometer works fine for reading surface temperatures But Absolutely WILL NOT READ AIR TEMPERATURE AIR CONDITIONING TEMPERATURE CAN NOT BE READ OR SENSED WITH AN IR GUN ! You need to use a THERMOMETER to read Accurate Air Conditioning Air Temperature !!! PEOPLE WHO POST IR GUN PICTURES AIMED INTO AN AIR VENT SHOWING LOW TEMPERATURES BELOW 32 DEGREES AND SAY THEIR EVAPORATOR DOES NOT FREEZE UP DURING EXTENDED DRIVING ARE BS!!! |
you can not fix stupid on some people |
shop will not be happy I have told the world about my discovery I let them use
| All times are GMT -8. The time now is 03:00 PM. |
