Agreed - look at the absolutely horrible results that my technologically obsolete a/c components provide! And obviously, my serpentine fender condenser has its limited effectiveness cooked out of it by the exhaust! Shame on those who designed, sell, install, buy and use these garbage products! I guess I should just throw all of my system upgrades away and start over! This photo was taken on a 98 degree day, car idling in my garage (1K RPM idle speed), high side pressure of 210psi and lowside of 30psi, max fan and thermostat settings, no evaporator freezing even after extended operation. http://forums.pelicanparts.com/uploa...1428340493.jpg This was taken on an 86 degree day - car idling in garage immediately following being used for errands (combined highway and city driving, moderate traffic, and at least two times parked in store parking lots - aka: heat soak). http://forums.pelicanparts.com/uploa...1428340520.jpg |
I am sensing an endless looping stream of the same message from OP.
The point has been made but remains unverified. Is there any sense/value in this thread continuing? |
<iframe width="640" height="390" src="https://www.youtube.com/embed/HktV2yGtLv8" frameborder="0" allowfullscreen></iframe> |
Thanks! |
Ronnie,
Maybe he's calling BS to your statement "no evaporator freeze up even after an extended period". At the sub-freezing level of the guage you picture the Rh would have to be practically ZERO for that to happen. Someone correct me if I'm wrong but it seems to me you need a rewrite of the laws of physics to have that happen. That's the base problem with using a CCOT charging procedure with a TXV system, the TXV doesn't have enough range to compensate for such a low refrigerant charge so you must rely on clutch cycling(***) to prevent evaporator freeze up. *** Cycle the compressor clutch off a few degrees above freezing and back on a few degrees above that. Remember that the liquid refrigerant stored in the R/D will result in "coast" period of cooling even after the clutch is cycled off. I NEVER wish to see myself siding with KeloGes on any matter, but... |
Will, I can't explain why I don't have problems with evaporator freezup, but I don't, and if I did, I would post asking for assistance.
I have "tested" my current setup in many varying driving conditions, including 70+ mile highway drives after dark in the summer when the temps are still in the mid to upper 90s and the humidity is very high, and have not experienced evaporator freezing. Of course, when the sun is down, and with a system capable of churning out such cold air, I do not need to run the thermostat on max even to meet my "unique" comfort needs, so perhaps if I did, the evaporator would eventually ice? But that is not what I call a "real world" operational situation for me - not a concern of mine, in other words. |
Hi Ronnie,
Could it be that your humidity is too low to create ice and freeze the evap? I don't know your climate. Also, high evap blower speed will help prevent freeze up. Dave |
http://forums.pelicanparts.com/uploa...1428367231.jpg |
YOUR TEMPERATURES AND PRESSURES and YOUR TESTS YOU CLAIM ON YOUR 911 ARE A BS LIE! AND/OR You have a special deal with GOD only you have ON THIS WORLD roflmao |
Looks like Ronnie is getting pretty darn cold temps at the vent seeing as how the thermometer has frost on it!
Disclaimer: I don't have A/C on my 911 as it was ordered without it. |
BTW? If you are roflmao how can you type? |
Zippy - got it and will get back to you.
Gary - you Sir, are neither a scholar nor a gentleman and are deserving of about twenty http://www.sherv.net/cm/emoticons/fi...y-emoticon.gif !!! Dave - extremely humid in North Texas year round (though not what Karl faces in Miami FL) - I usually have my fan speed on high, so maybe that helps explain things. I like the air movement then, and the noise doesn't bother me because I can't hear it over the engine/exhaust or the blaring Slipknot. :D Reid - I would expect nothing less from someone who does not have the results to back up his chest beating - good job representing your "types". Bob - yo' mama! Wayne - that's not frost, but dandruff from Bob when he used the thermometer to take is own errrrr, ummmmm "temperatur" . . . I soaked my hands in peroxide immediately following that pic! |
Reversing the gases
Dave I posted 911 Diagrams for you to help you visualize what Porsche did wrong
and is still being done wrong by others This should help you figure out REVERSING THE GASES and understand better |
Now can somebody shut this pathetic thread down. I swear to God, I will make it my life's work to oust you. You are an embarrassment to the thinking man. Edit: You got nothing. You are the liar. |
The only way I can see for preventing condensate accumulation in the cabin is to provide fresh inlet airflow, blower forced or forward speed, HOT/HUMID fresh inlet airflow. |
It's definitely a puzzle... Speaking of which haven't I seen KeloGes making the same claim, system so good it produces sub-freezing vent temps? Plus haven't I seem KeloGes espousing the same refrigerant charging technique as Charlie? Charge ONLY to the level that gets a the best sub-freezing vent temp? |
An explanation, maybe....
Due to the hysteresis span of the thermostatic switch plus the level of liquid refrigerant remaining(system cooling "coast" time) in the R/D at clutch off time the low IR you got might be perfectly normal. The time constant of the compressor on/off periods is fairly long, you might well measure a sub-freezing temperature, especially during the initial clutch off time ("coast" time) as long as the switch hysteresis causes the clutch circuit to remain off/open for and equal or slightly greater time with the evaporator above the freezing level. Result, the AVERAGE evaporator core temperature over the complete system cycle time is slightly ABOVE freezing. Hold the PR trigger on for an entire system cycle period, or even several, and then check the min/max readouts...SmileWavy |
If the car has X units of moisture inside and eventually all freezes inside the evaporator, what is the amount that freezes it to the point of non-operation? |
so ok you think I have got nothing then go away back to your beer and someplace else |
Will, I'm sure you are onto something about the core temp typically staying at a temperature slightly above freezing. I've never tried to determine that because the system has performed so well (nothing to trouble shoot, etc).
It would be interesting to see how much moisture is wicked into the cabin - no indication of visible moisture on the vents and such and the air inside the cabin feels crisp and fresh - the opposite of humid, in other words. |
The only recent example, recent being circa 1993-4, was in our 1992 Lexus LS400. Each instance involved driving up rising terrain, McDonald pass in Mt, I5 in northern Ca. In each the instance the evaporator airflow was practically non-existent by the time we realized the cabin was becoming uncomfortably warm. It only took a few minutes with the compressor off to return the system to normal operation. |
But, would you buy if she came a knockin' at yer door?!?! http://cdn.gunaxin.com/wp-content/up...irls_scout.jpg |
From my perspective that is a shooting from the hip, for spite, lie. Then I am degraded for my squillion post count and talking of or drinking beer. It ain't the AC talk that frosts me. |
Go read "scientific laws of Thermodynamics" Laws of thermodynamics - Wikipedia, the free encyclopedia en.wikipedia.org/wiki/Laws_of_thermodynamics Wikipedia The four laws of thermodynamics define fundamental physical quantities ..... to Entropy: Statistical Thermodynamics Based on Information, World Scientific, New . treaties on planet earth aplied to automotive A/C System I am done with you go sit in the corner some place else |
Reversing The Gases Works Far better than Porsche's Engineers OEM Design
Back To The Topic of this Tread
Reversing The Gases Works Far better than Porsche's Engineers OEM Design THIS IS NOT BS My discovery works great, and I give it for free TRY IT YOU WILL LIKE IT!!! Believe it or don't |
Otherwise we must trust your memory since you agreed that you kept no records. |
Pictures came from the actual "reverse" trial?
Low side -5 PSI high side 140 PSI... I'm in the dark completely on this one, please explain.. http://forums.pelicanparts.com/uploa...1428443176.jpg Guages in focus for clarity. http://forums.pelicanparts.com/uploa...1428443211.jpg |
Low side minus 5 PSI = ~22 degrees below zero, yet your reading was only just barely sub-freezing...??
How so, blockage to flow between the evaporator outlet and the compressor inlet? Oh, sub-freezing vent temperatures are still BS..?? http://forums.pelicanparts.com/uploa...1428443786.jpg |
<iframe width="640" height="390" src="https://www.youtube.com/embed/TmIuXyiEzCE" frameborder="0" allowfullscreen></iframe> |
| All times are GMT -8. The time now is 12:53 PM. |
