SCadaddle's Avatar
clink, clink, clink, CLANK!
82SC. Sounds like something in the exhaust system is giving me a garbled metal on metal resonation noise when cold and during warm-up but then sounds fine. After driving and up to full temp (190-200F) and then shutting it down the exhaust system goes through the cool down clink, clink, clink, clink then a single loud CLANK! sound. Thinking maybe the accordions in the cross over pipe? Anybody have a clue where to look for typical contraction/expansion binds in the system? Not a dilivar head stud issue as that has been resolved with steel studs. Thanks.
Old 04-05-2015, 09:42 AM
El Duderino
tirwin's Avatar
What is your exhaust setup? Sounds like stock heat exchangers. Cat and stock muffler?
A couple of ideas... Just spitballing...
Metal straps holding the muffler?
The heat shield around the cat?
Exhaust stud?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-05-2015, 11:03 AM
SCadaddle's Avatar
Stock exhaust with the exception of a gutted cat. Leaning towards a M&K Euro Pre-muffler if it would be more quiet than the gutted cat.
Old 04-05-2015, 01:36 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I like Tirwin's thinking. Loosen the muffler straps a little to make sure you can.
Drive it like an idiot for a bit and then bring it into garage. Take the weight off the muffler just a smidgeon with a floor jack and loosen the straps again see if noise repeats when cooling.
It may be something silly like the shrouds around the header pipes. Just put a wee bit (I am talking tiny bit with a 2 X 4) of floor jack pressure on them after a drive and listen to isolate.
1981 911SC Targa
Old 04-05-2015, 02:14 PM
Banned
Bob can relate to the thread title; he hears the exact same sounds each time he turns his head!!!
Old 04-05-2015, 02:50 PM
make sure its not a chain tensioner going south. ive had 2 pressure fed tensioners fail, one just last week.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 04-05-2015, 03:05 PM
stormcrow's Avatar
Could be loose tensioner. I just pulled my engine and pulled the covers - the tensioner on the drivers side was slack by about 1/4".
So that could be what's going on - the chain could be slapping against the engine housing.
SteveKJR
Proud Owner of a 78 911 SC Targa
"A Porsche does more then just go fast in a straight line"
Old 04-05-2015, 07:08 PM
