Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
1981 SC cyl 3 not firing - HELP!
Hey all, it's been a long time since i've posted...
My 81 SC (US spec) has an issue I can't figure out.
Cylinder 3 won't fire.
- No air leak
- Intake runners are good
- Injector has good spray pattern
- Compression good
- Leak down good
- Tried different spark plugs
- tried different plug wires
- tried different cap, rotor
- has spark
- tried different injector
- tried different ignition control module
- new fuel injector o-ring and sleeve
- scoped the cylinder, and the combustion chamber and pistons look great
- tried different fuel line
Runs smooth on highway, misses obviously at idle (slightly lumpy w/ intermittent popping from exhaust), poor gas mileage, especially in stop and go traffic.
I don't know where else to go...
It's getting fuel, air, and spark... wtf?
Thanks in advance, everyone...
edit: Also, idle is usually good, but after idling for a long while, or after a warm start, it will rise to about 1400-1500rpm
Old 04-14-2015, 06:55 PM
Functionista
manbridge 74's Avatar
Leakdown, provide numbers and done hot or cold.
Compression, provide same and include answer to did you block throttle open and have a battery charger on car?
Old 04-14-2015, 07:02 PM
I don't have that information. The car is at a shop in the area.... i'm just hoping for some off-the-wall ideas to throw at them...
Old 04-14-2015, 07:09 PM
Functionista
Data. Gotta have it.
Old 04-14-2015, 07:47 PM
Leakdown: <5%
Compression: 170-175
tested both hot and cold, throttle open, on charger and off
Old 04-14-2015, 08:00 PM
apparently the compression is significantly lower, on the low end of spec, in cylinder 2, but that is firing just fine.
They tried swapping the fuel lines from cylinder 2 to 3, no change
They tried swapping distributor, no change
Old 04-14-2015, 08:01 PM
Walt Fricke's Avatar
What do the plugs look like? Is the #3 significantly different? Looks leaner? Looks richer?
Do you have an infra red thermometer gun? After (or while) running the engine, can you take temperatures on the headers right at the exhaust ports (before they enter the heat exchanger) to see if the #3 exhaust is cooler (which it will be if that hole doesn't fire).
You might run it on a chassis dyno, and take air/fuel ratios both at idle, and at high RPM. You might be able to differentiate between an idle issue in #3, or whether it just isn't pulling its weight on the highway (these cars are not slugs running on only five cylinders).
Have you pulled the intake valve cover off and checked to see that both the intake and the exhaust (you can spot a bit of its rocker where it is on the cam) are behaving as they should?
Old 04-14-2015, 08:34 PM
El Duderino
tirwin's Avatar
This is a real head-scratcher.
This may be scraping the bottom of the idea barrel, but the spark plugs are grounded by the case. Is there some way that the plug in cylinder #3 has become electrically isolated? I can't think of how off hand... I'm just spitballin'.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-14-2015, 08:56 PM
I'll get more information tomorrow evening when i talk to them again...
I'm just having these horrible visions of needing to rebuild the engine or something... that is terrifying to me as i just can't afford to do that...
could something like a valve adjustment be a possible culprit?
Old 04-14-2015, 09:23 PM
they said that the plug was dry when they checked it, and have tried multiple plugs... also they said the threads in the head looked ok, so it SHOULD be grounding properly...
im getting freaked out because these guys have been in business for a long while and are almost out of ideas...
Old 04-14-2015, 09:24 PM
Functionista
Out of adjustment valves should show up on leak down/compression test if they are so out as to cause a complete no fire. Same with flat cam lobe.
If the shop has no IR gun have them put their finger literally right on the exhaust pipe where it exits the port but before heat exchanger on a cold start. They should all be untouchable in a minute or less. Obviously the IR gun is best but I've done the above many times over the years with good accuracy if the cylinder is a dead hole.
Old 04-14-2015, 09:45 PM
I'm sure they have a heat gun. That was how they were able to tell that the cylinder wasn't firing. They said that it was cold...
Old 04-14-2015, 10:01 PM
And won't running the engine with a dead cylinder cause damage? What keeps the cylinder from hydrolocking from the fuel?
Old 04-14-2015, 10:05 PM
Still here
pmax's Avatar
How certain are they the cyl is not firing ?
Old 04-14-2015, 10:09 PM
Functionista
Off the wall.... considered another shop?
Old 04-14-2015, 11:31 PM
Dr J's Avatar
Just in case, it would be good to double check that the nuts from the intake runner to the heads are tight.
Old 04-15-2015, 06:11 AM
Tip of the day........
pmax,
This is what I would do to determine if the questionable cylinder is really not firing(?). Forget compression, leak down test, air leak, etc. for the meantime and focus on this test. Remove the FP relay, have a fully charged battery, and hook up an inductive timing light or a spark plug tester to #3 and crank the starter several times. Try to test cylinders #1, #2, and #3 to compare the individual intensity of the strobe light. Keep us posted.
Tony
Old 04-15-2015, 07:28 AM
+1.. Seems to me someone is making a mountain out of a molehill.. Should not be that hard to track down..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 04-15-2015, 10:12 AM
Fleabit peanut monkey
Bob Kontak's Avatar
If your valves are opening you have no issue.
Originally Posted by boyt911sc View Post
.............test cylinders #1, #2, and #3 to compare the individual intensity of the strobe light.
Do this.
How so (cam lobe)? Flat cam would not open the valve. Let's say exhaust valve does not open. How would that impact compression?
1981 911SC Targa
Old 04-15-2015, 06:39 PM
Functionista
I'm thinking that worn lobes wouldn't be so flat that valve wouldn't open some. I do know that there will be a difference compared to other cylinders if they are healthy. I would also do a dynamic compression test as well, looking for anomalies.
Old 04-15-2015, 09:57 PM
