Smoke while warming up, from what???
Purchased a 964 C4 back in January. Car is in great condition with records back to '93. Only has 87k miles. PPI came up very clean except for the rear swing plate bushings (damn those bushings are expensive?!?) and a very minor leak on a valve cover.
I drove the car once delivered about 1,000 miles with zero smoke on start and warm up. I took the car to have the oil changed and valves adjusted to get a maintenance baseline for my own records moving forward. My local mechanic, John Walker (who is an acclaimed PNW air-cooled mechanic dating back to the 60s) adjusted the valves, changed the oil, and inspected the car. Everything came back great (except for the swing plate bushings) and he praised the condition of the car. He intentionally filled the oil tank low, like you're supposed to.
About 200 miles into the fresh oil change and valve adjustment, the car began to smoke from the tail pipe. The smoke doesn't show until about 30-45 seconds after startup and seems to continue until the car is warm. I haven't noticed it too much once the car is hot, but it's also been at night when it's more difficult to see (it's dark quite often up here). The smoke doesn't smell like the typical exhaust smell on a cold day (like in the photo below). For the most part, I've only been doing around town driving (less than 20-30 miles, 2 or 3 days/week). It isn't the classic oil leak 1 plume of smoke once started up, it seems different. There is a lot of moisture here in the PNW that could be steaming off, but it wouldn't be constant?
Anyone have any ideas? Checking the oil right after an oil change has proven difficult. Clean oil on a dipstick is very difficult to see and my oil gauge seems to always be in the red with the occasional (after a long drive) coming up to 4 or 3 o'clock. The gauge range hasn't changed pre or post valve adjustment/oil change. I'm very hesitant to put more/too much oil into it, but I imagine oil is burning somewhere. Would driving the car only around town be the culprit? In reality, the car is only really at a warm temperature (temp gauge at 8 o'clock) for 10-20 minutes each drive, could that be it? Do I need to get it warm for 30+ minutes?
Any input or advice would be appreciated!
Chris
Old 04-16-2015, 09:51 AM
Here are the clues:
There is a lot of moisture here in the PNW.
the car is only really at a warm temperature (temp gauge at 8 o'clock) for 10-20 minutes each drive.
Given your mechanic (JW) and the other factors you describe, added to the clues, above, I'm betting you're seeing moisture from the crankcase/oil tank. It's very typical for water vapor to be seen early on in a cold start, and last a bit longer in situations like yours. The boiling off of water in the oil will take a bit of time at high temps. Your driving pattern doesn't seem to be enough to fully get rid of the moisture which is collecting in the oil tank. Take the car out for a good, long drive at freeway speed and you'll likely see the "smoke" appear early, and disappear, completely, shortly thereafter.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-16-2015, 10:44 AM
+1.. My 81 SC use to do the same thing. When I drove it short distances and tucked it away for days. Started driving her longer to get it heated up and the problem disappeared.
Old 04-16-2015, 11:01 AM
you live in the PNW, where the air is full of humidity. That air is sucked into the engine and the water is burnet off into steam. In addition, a by product of organic combustion is H2O, and that too is burnt off into steam.
That steam shows up as white vapor on the exhaust port. Normal. Drive it more.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-16-2015, 11:13 AM
Still here
pmax's Avatar
Also sounds like you are warming up the car by idling it for 30-45 secs.
That's too long.
Old 04-16-2015, 11:25 AM
virob's Avatar
I'm also in the PNW. The white steam is normal. I only take the Porsche out if I can drive it at least 30 min at operating temp at speed to get the moisture out before putting it back in the garage. I live about 6 miles from work, so it is not a daily driver. I don't think the car (any car for that matter) likes the short drives, especially city drives.
84 911 Chiffon white
Old 04-16-2015, 11:49 AM
Thanks for the feedback. It seems like all of the symptoms align with just shorter drives around town and vapor. I thought the same thing at first, but was a little concerned with how long the smoke came out and that smoke isn't white, it's almost blue in color. Is that typical of Vapor? It has a different scent as well, not the normal of exhaust. Does that align with water vapor?
I'm planning to stretch her legs this weekend, hopefully that clears it up!
Old 04-16-2015, 12:15 PM
Blue is not water.
Old 04-16-2015, 12:45 PM
RETIRED
Joe Bob's Avatar
If it sits for awhile.....it will smoke at start up. Drive it like a rental.
2012 ML350 3.0 Turbo Diesel
Old 04-16-2015, 02:40 PM
twistoffat's Avatar
Check the inside of the oil filler cap for moisture build up(yellow gunk). If its there you need to drive it more at the others have said to burn off the moisture.
Old 04-16-2015, 09:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Drive Off immediately, our cars do not need to be warmed up just keep her under 3500 RPMs for the first 10 minutes, verify with PAG owner's manual it will say something very similar.
White/Grey smoke is vapor. Do not worry about it and try to take her for a long drive to burn off the moisture. After this start her, she should be nice and clear on start up.
'85 Carrera Targa
PCA/POC
Old 04-16-2015, 11:00 PM
scarceller's Avatar
Does it only smoke while at idle? Does it get worse while driving during decel?
If only at idle and just for a few minutes I agree with others that most likely not an issue.
You could pull a plug from each cyl to see what they look like.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 04-17-2015, 04:31 AM
Not Quite Banned
Thomas Owen's Avatar
Where do you park it at night - inside or outside? Sure sounds like moisture to me, but most importantly, what does John say about this? If it is a phenomena of that area with a 911 I am sure he has seen it...
Thomas Owen
1972 911T
1972 911S
Old 04-17-2015, 05:23 AM
crg53's Avatar
You could have a power steering fluid leak, or a leak from the power steering drive. Either of these will leak fluid down onto the right hand side heat exchanger, that then will start smoking in around 20-30 sec after start up. Check part # 5 & 6 in the picture HERE .
Old 04-17-2015, 06:34 AM
OsoMoore's Avatar
Originally Posted by ossiblue View Post
Here are the clues:
Take the long way home! My commute is just 4.5 miles, so I like to pick up my wife and hit the back roads for an hour, at least once a week.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 04-17-2015, 06:58 AM
