Member 911 Anonymous
DRACO A5OG's Avatar
Thumbs up LEAK Finally Fixed the Darn Oil Return Pipe with 36MM/32MM nuts
I just wanted to share my OIL LEAK FIX!
The Story:
About 4.5 years ago I had a wrench try to fix my oil leaks. I was just too busy and really wanted the damn oil stop doing the Valdez on my drive way. Unfortunately, on day 3, the fix created more leaks. Oh the Joy. I was just too busy to take her back so, I chalked it up to "Eh, It's 911, it supposed to leak". Right Fellas?
My main culprit was the 36MM Oil Return Pipe Fitment that goes into the 32MM nut to the engine block.
It was loose ever since he replaced my 5 oil return tubes. To be honest, not sure if he even checked to make sure it was secure. But seriously, the oil return pipe was loose to the touch, moving up and down and the 32MM fitment moving on the engine block. I can see the darn oil dripping not sweating but dripping. I tried to use a punch tool to tighten it, So I said to self, Yeah right Moron, there is no easy way.
I was really dreading this task because I read all the horror stories about locating a skinny wrench or something extra special and rusty nuts. Not to mention having to remove the oil return tubes to be able to tighten the two nuts (36/32MM). Oh the Joy.
TASK:
So I pulled the trigger.
Drained engine only. It dumped 3.5 Qts of oil. Take NOTE ( I recently changed the oil so did not want to waste all the new oil in her )
Removed the Stainless Steel Engine Piping to Heat Exchangers
To my delight, the three 8MM Barrel nuts and 13MM Hex Lock Nut, looked in great condition. I guess one of the only benefits of a leak is, it will keep the metal rust free??? JKDs but lucked out!
I sprayed some Kroil on those 6, the 3 Cat/Exchanger nuts, 36/32MM nuts, Return Tube at Engine Block.
The heat exchanger came right off, using a 13MM crows foot with angled extension and lucky the mechanic used the updated gaskets.
OMG!, it was filthy fully of caked on old oil from 4.5 years of being an imbecile and driving like that. What the heck is wrong with me?
RETURN TUBE REMOVAL:
I removed the CirClip, used a BFS and pryed the tube back to expose the green o-rings . Popped right out and proceed to use the BFS to push the end back just enough to clear the 36MM/32MM nuts.
I know, I know, I should replace it but, I was very gentle and did not touch the o-ring with the BFS.
36MM/32MM NUT.
I used the BIG OIL Line Black Wrenches used to remove the super tight 36MM nut to Front Oil Cooler line for the engine drop.
I held the 32MM nut, loosened the 36MM and unscrewed more than half way to make certain the 32MM wrench will have enough room for the wrench to have enough clearance. I had a replacement crush washer but the one that was in there was pristine so I thoroughly cleaned the area and torqued it down.
Unfortunately, I did not have a 32MM Crows foot so I used the "Snug and 1/8 turn" technique.
Well, that was not enough, the weight of the pipe just makes the 32MM fitment move. So I went another 1/8". Sucker will never move again
I proceeded to tighten the 36MM Oil Pipe Nut. BTW, no special skinny tools needed if you loosen the 36MM nut. I held up the oil return pipe and torqued the 36MM down. You must hold the pipe up or it will ride on the Heat exchanger. Ask me how I know :-/
The Oil Line Wrenches are a GOD SEND :-). Thanks Brother JinKatin
Success, Oil Return Pipe is SOLID as it should be.
BACK TO THE OIL RETURN TUBE:
I cleaned both engine Block and Green O-ring, added motor oil.
Used a vise grip to hold the Valve side and a BFS to gentley push the tube back in. Plopped right in with a little pressure. The Vise grip side with the valves popped out half way so I used the vise grip to pop it back in. Replaced CirClip. Insured circlip is not touching the return pipe since I pushed the pipe up to clear the exchanger.
HEAT EXCHANGER:
I had a spare generously donated by Brother GILLES&KATHY. Mine had a leak. Yes, exhaust leak at the cat/mufler connection.
18 ft lbs on all nuts
30 ft lbs on the Muffler Straps
Added 3.5 QTS OF NEW OIL:
Started her up. BE WARNED IT WILL SMOKE So I drove around the neighborhood to my uppity neighbor's dismay until smoke dissipated. Pulled into a gas station and verified, NO LEAKS Hoorah!
Hopped on the Freeway to bring her up to Operating Temps to top off the oil to the middle hash mark on the dip stick. ( for the noobs, just incase but we no better right :-) )
Pulled into my garage, filled the oil, looked below. YUREKA! she be DRY!
Why the heck did I wait so long to do this???
Jim
'85 Carrera Targa
PCA/POC
Old 04-16-2015, 09:25 PM
DRACO A5OG's Avatar
The Culprit after Fix
Yes, I placed a mark <
Item #18
The Oil Return Tube that needs to be Loosened:
Updated 8MM Barrel Nut and 13MM Lock Nut
Mini Valdez
Exhaust Leak even with New Gasket
Thanks Gilles
Will take a pic after week to verify she be DRY
'85 Carrera Targa
PCA/POC
Old 04-16-2015, 09:27 PM
Congrats on fixing your leak!
One note - is that a nylon lock nut on the heat exchanger? If so, I'd recommend swapping that out for a different fastener. The nylon won't survive in that environment and the 'lock' functionality won't be worth much.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 04-17-2015, 03:30 AM
db_cooper's Avatar
Looks like a 13mm nylock nut on your exhaust stud(s) in the picture. I sure would use some copper exhaust nuts..
Old 04-17-2015, 06:28 AM
DRACO A5OG's Avatar
Thanks Fellas,
That is what I thought, but these nuts have been on for over 4 years vs my other side with ones I replaced 3 years ago that had rusted out.
BTW,
Where do you get these:
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 07:22 AM
I believe I ordered them from our sponsor a couple of years ago.
Tom
Old 04-17-2015, 07:53 AM
DRACO A5OG's Avatar
^^^ Our Host?
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 07:54 AM
Yep, that's where I got mine as well. Our host sells the copper lock nuts.
Old 04-17-2015, 08:00 AM
DRACO A5OG's Avatar
+2, the same ones on the passenger side that rusted :-/ but I don't think they sell the "SLIT" version, which would be cool. Calling them now.
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 08:03 AM
DRACO A5OG's Avatar
Confirmed, our Host only sells the oblonged end copper clad nuts M8x13Hex
900-910-097-02
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 08:19 AM
Under the radar
Trackrash's Avatar
Thought I got these from Pelican.... They are 12mm.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-17-2015, 08:31 AM
Under the radar
Trackrash's Avatar
Here it is.
1978 Porsche 911 SC Coupe - Miscellaneous & Hardware - Page 1
Gordon
Old 04-17-2015, 08:51 AM
DRACO A5OG's Avatar
^^^ x 2, Yeap those are 12MM Hex for the Cat/Muffler fitment.
I think Heat Exchangers require 13MM Hex, No? I guess it would not matter as long as they fit as M8's, right?
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 09:00 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Nice job Jim!
No need for lock nuts on the exhaust IMO. They don't come loose. In fact we all struggle to get them loose! Even when a lot of anti-seize is used on regular nuts, they still don't loosen.
Kevin L
'86 Carrera "Larry"
Old 04-17-2015, 09:13 AM
Under the radar
Trackrash's Avatar
That is what I have used (12mm hex) on my heat exchangers. The flange at the bottom on the nut will make it hold. Use anti-seize.
Mind you, I have the old style heat exchangers. On my car the 12mm hex makes it easier to get a wrench on a couple of the nuts.
Gordon
Old 04-17-2015, 09:17 AM
DRACO A5OG's Avatar
Thank you KTL!
Brother Gordon, I was thinking the same. Those 13MM Hex are really tight space wise. Had to use a swivel extension and crows foot.
Any who, ordered the PAG 13MM Hex Copper Clad
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 09:41 AM
French Import
zippy_gg's Avatar
Jim, glad you got that pesky leak fixed!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 04-17-2015, 01:50 PM
DRACO A5OG's Avatar
It always bothered me especially that day when you said you smelt oil burning :-)
Not blaming you, heck that was two years ago. I am such a procrastinator and it was so easy to do.
'85 Carrera Targa
PCA/POC
Old 04-17-2015, 02:08 PM
French Import
zippy_gg's Avatar
My bad...! I do that to people...
Gilles & Kathy
Old 04-17-2015, 02:25 PM
Unfortunately someone changed mine the po or a moron mechanic and cracked my case.
Old 04-17-2015, 02:49 PM
