AC completely died, trouble shooting help needed
Today I was driving with the AC on working fine, as it has for months. Turned the car off at a store, turn back on and no AC. No fan, no blower, nothing. Turned the switch several times, nothing. Went and check on Relay #1 in the trunk, swapped it with one from another slot, nothing. All the fuses look ok. What else should I check?
It's the original compressor (1981 930) but rest of system has been upgraded to R134 (evaporator, condensor, hoses).
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
Member 911 Anonymous
Check the fuse/relay in the smuggler's box
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Banned
+1 with what Draco said.
When the points in that relay stick (or it has some other problem) nothing in the a/c system will work. One thing you can try as a "test" is to tap/smack the relay with something and see if it "frees up" and starts working. Regardless, they are cheap and easy to replace. |
88 Carrera, Guards Red
your going to regret asking an AC question on this forum. any moment now..
Long as it is the same amps.
I think I read somewhere that the all electrical circuits in a 911 will work better if your reverse the flow of the electrons... no, sorry, must've imagined that.
Current ride: 2004 Mitsubishi Shogun Sport Back in the US: 1979 911 SC (closer to completion), 2011 H-D XR1200X (storage), 2005 BMW R1200GS (in transit). Past (too many to list them all): 2011 BMW X5 35d, 2006 Subaru WRX, 1987 Porsche 951, 2007 Mustang Cobra, 2004 Mustang GT, 1976 Toyota FJ-40, 2001 Buell M2 |
Ours died while working fine a few years ago, it turned out to be the console switch. The contacts were burned and finally gave up. Replaced it, works.
Another simple test is to put 12 volts to the red side of the AC blower connector. Ground to the brown side wire. If it blows you know it works and can start to trace down where the problem is. Very likely it is the relay.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relay.
![]() ^^^^ From our host. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
That's interesting. The one I have says 30 A max. Would it be better to use a higher or lower amp relay?
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 04-20-2015 at 11:15 AM.. |
A big +1!!!!!
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Just replaced the relay in the smugglers box and I'm back in business with, working AC! And no, I don't regret posting about AC questions. You guys saved me a couple of hundred bucks. Thanks DRACO , Ronnie and 86 911 Targa.
UnRegistered User
Someone had a problem. Some people suggested some VALID solutions for this problem. Problem solved. Nice not to have the stream of verbal diarrhea that accompanies most of these threads. Well done, gentlemen! Now back to your regularly scheduled A/C thread....
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
