What have you done to extend your original steering wheel for better position?
I´ve got a 911 SC built in 1982 and I like the original steering wheel. What I not like is the actual seat position. If you are over 6 feet high you have to stretch your arms very much.
I know there is an original steering wheel with a spacer (M018) but there is no chance to get one. The last one in Ebay was sold for nearly 1.000 $.
How have you solved this problem? Do you use some handmade spacer and how do you made them?
Thanks for your responds and best regards.
996 Carrera 4 Cabrio, 2001, 300 hp, silver, black
911 SC, 1982, 210 hp, white, pascha
912, 1966, 90 hp, light ivory, black
Old 04-21-2015, 08:55 AM
You can find 6-hole spacer/adapters all over the Internet. I bought the J-West offset adapter (sold here on PP) which extends and raises the steering wheel. Recommended.
Old 04-21-2015, 09:20 AM
Charles Freeborn's Avatar
I made my own:
Here's a thread showing the spacer at the base of the column:
Spacer for stock steering wheel
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 04-21-2015, 09:41 AM
Eva
911SauCy's Avatar
I'm 6'2", added 1.25" wheel hub spacer (tough to see but it's there) and the deep dish momo. The car fits me as intended, perfectly.
Recently drove a friends '83 and I forgot how much I missed crushing my knuckles into the windscreen
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 04-21-2015, 10:27 AM
JWest Engineering
Old 04-21-2015, 10:40 AM
TheSt|G's Avatar
JWest spacer paired to a 3" spacer. At 6'5" this gives me an amazing driving position.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 04-21-2015, 11:12 AM
Thanks a lot for your replays.
Charles, your solution is very interesting also the link. I´m not sure I think there are two possibilities:
1) I copy Charles solution
2) I cut the original fastener and welding a spacer between the fastener and the steering wheel
The other solutions like JWest spacer are only for aftermarked steering wheels, isn´t it?
Old 04-22-2015, 11:46 AM
Home - JWest Engineering
Pretty sure it is only for Momo wheels.
Old 04-22-2015, 12:35 PM
I would rather be driving
jpnovak's Avatar
At 6'3". I use a 2" spacer and flat dished Momo wheel.
Ergonomics make the car great.
The problem is that once you move the wheel you will want to move the shifter...
Old 04-22-2015, 12:38 PM
Checked out
McLovin's Avatar
The factory extended wheel doesn't really command more on the market.
They are fairly common, too.
You'll find one for $150-$200 if you look around a little and give it a little time.
Old 04-22-2015, 12:43 PM
Skunk works
JV911SYDNEY's Avatar
Rennline quick release
964 RS-4
Old 04-22-2015, 03:59 PM
