Eric,
What Willy can't "absorb" is that he thinks a deck lid condenser is going to absorb AND transfer into the refrigerant enough heat to push the pressure in a static system above 450 psi or whatever. In order to reach 450 psi with R134a you'd have to raise the entire high side near 195F ..... complete absorption! It ain't gonna happen. You can cover the deck lid with 10 feet of insulation foam, it ain't gonna happen. Regardless as to how much heat, radiant, convected or conducted, or a combination of the 3, the engine compartments residual heat loss when turned off simply can't raise that much total value of heat (btu's if you wish) to push the high side up to 450 psi or higher. Now, the other hand, if we want to use some old school heat transfer with our refrigerant we can wrap the headers with metal tubing and let them 'pump' up the juice and toss away our compressors.
Banned
And maintained there, for a significant time. wwest is just plain WRONG. Not mistaken, but stupidly, idiotically, and painfully WRONG. |
Fleabit peanut monkey
It's filibustering simply to disrupt continuity for spiting Griffith.
1981 911SC Targa |
Chain fence eating turbo
How can someone bash another, but then follow up with a question back at the person they bashed for a better understanding of the argument they started?! WTF?!
Borderline psycho..... |
Banned
Of course it is. And to chase folks with real concerns off. To Wayne Dempsey: Are you seriously so laissez-faire that you'll allow this sort of crappola in the tech forum? I understand this kind of schitt in the FS forums, but this ain't a FS forum.
Banned
Banned
Yep, and the funny thing about all this is that people with a/c setups that place condensers near heat sources, and in the deck lid without a supplemental fan of any sort (Turbos do not have the cabin heater fan that other 911s do), do NOT report problems with shutdown over-pressurization, or that their systems are incabable of delivering ball freezing temps in very hot climates. Very, very strange behavior from the wild one.
Banned
Banned
Back when R-12 was used available binary pressure switch high side limit was 380 to 450 PSI. So 450 PSI was not unheard of for an R-12 system, possibly quite common. Our systems do not come with a pressure switch, our compressors will run until the thermostatic switch setting is satisfied, max setting, 30dF, or according to Griffiths, 27dF. How tightly closed will the TXV be as the evaporator temperature declines to that level? My Porsche owners manual indicates that at idle with the A/C loaded, widows open, the R/D sight class should indicate a level of liquid. Oh, and it does exactly that. How high might the pressure go at 2300 RPM and the cabin Rockwall comfortable..? Any guesses..?? No wonder the EPA requires that R-134a conversions include a pressure switch upgrade. Otherwise tripping those ~500 PSI HPRVs would be a regular event. |
1981 911SC Targa |
Immature Member
A low pressure cutoff is there to protect the compressor in the event that refrigerant is lost... not a normal event. Likewise, reaching pressures of 400 psi is not normal. A high side cutoff is there for protection, not normal function. HPRV is for a blockage in the TXV that could result in catastrophic bursting of the system. How many threads have we seen that started with "My AC system just burst and spewed out hot oil all over my engine bay"? None. So why do you persist in answering the questions not asked?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Banned
Because of his monomania. He hates Griff, so he'll say anything, anything at all, to cast doubt.
Report his posts as spam and trolling. Every time, all of them. I am removing him from my ignore list to do just that. |
Let's kill this snake.
1981 911SC Targa |
Banned
Banned
LOL.
Is that Squidward?
1981 911SC Targa |
Banned
No, it's Moses.
That's gonna be expensive.
Although it's Patrick.
1981 911SC Targa Last edited by Bob Kontak; 05-28-2015 at 09:23 PM.. |
