reesestewww's Avatar
Question Sudden 915 Slop - Movement in Shift Pattern.
Driving this afternoon I noticed that the shift pattern seems to have changed. That's the best way I can describe the symptom.
1st seems to feel almost where 3rd was, 2nd feels a tab to the right and so on. Even to the point where shifting into 3rd I actually put it back into 1st which i have NEVER done in 15 years.
All the subsequent gears are there, 3rd, 4th and 5th. However after 1st and second seem to have moved to the right in the shift pattern 3rd and 4th are very finicky to find and very close to 1 and 2.
Does this sound like busing, coupler, etc issues? Or something else potentially?
BTW I do already have a WEVO Shifter.
Thoughts? Thanks!
Past:
04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne
Old 05-04-2015, 12:53 PM
onboost's Avatar
Simple enough to pull the rear tunnel cover and check busing coupler... that's where I'd start.
Sounds like the clamp on the coupler/rod has worked loose.
RGruppe #180
Old 05-04-2015, 12:58 PM
Under the radar
Trackrash's Avatar
Most likely the coupler bushings have self destructed. Very common. Should check the other bushings under the shifter while in there.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-04-2015, 01:21 PM
faverymi's Avatar
That.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 05-04-2015, 01:24 PM
Thanks for the direction. Glad that I found this to be the cause. A quick search and found this and more inside the rubber boot.
Is this bad
Past:
Old 05-04-2015, 02:56 PM
Neilnaz's Avatar
It looks like you should replace all your bushings at the gearlever and the coupler. These jobs are straightforward if a little fiddly. There are instructions how to do these in the Technical section and plenty of threads where people have had similar problems to you. I did this job on my car although I didn't find catastrophic failure I did find 'tiredness' and updating the bushes took away vagueness.
The parts are not expensive but make sure you change all of them to be sure...
I hope that is helpful.
Cheers, Neil
Old 05-04-2015, 03:08 PM
onboost's Avatar
Wow, with a fresh Wevo assumption is those would be fresh as well. Good catch.
You still need to check your coupling in the rear to ensure that you get it all.
RGruppe #180
Old 05-04-2015, 04:00 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
bushing.
Is this bad
Yup-Here's was mine............................
also, as per the previous post, replace the shifter bushings.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-04-2015, 04:09 PM
Thank you all. I've ordered new bushings for the coupler and under the shifter from our host. They'll be here Friday. Just in time for another weekend project.
Past:
Old 05-04-2015, 05:19 PM
4flyboy's Avatar
Coupler Whisperer.....or Wevo or Rennshift....
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 05-04-2015, 05:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Keep us posted
'85 Carrera Targa
PCA/POC
Old 05-04-2015, 05:32 PM
Removed the bushings. Here are the results. The one's below the shifter look decent, however I'm still replacing them.
Past:
Old 05-06-2015, 12:33 PM
